Go to Post Learning by failure is quite common. - Gdeaver [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 14-01-2013, 17:19
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
SolidWorks Weldments
Do any teams cad their base structure using the weldment tools in SolidWorks?
If so what do you like about it?
If not why?
Good enough is the enemy of anything great!
team 1671
Unread 31-01-2013, 01:56
FRC #5817 (Uni-Rex)
Re: SolidWorks Weldments
Would still love to know if teams are taking advantage of these tools.
I am working on a tutorial to see them in action.
team 1671
Unread 31-01-2013, 08:50
Or 2230's Avatar
Or 2230 Or 2230 is offline
FRC #2230 (General Angels)
Or 2230 will become famous soon enough
We are using SW weldments to CAD some parts of our robot. it is much easier sometimes and much harder sometimes, depends on the complication of your robot
General Angels #2230 :
2009 IS champions + chairman's award
2011 IS finalists
Unread 31-01-2013, 09:19
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Our team has used solidworks weldments for the last three years, It is a little more difficult to learn, but i feel the bonuses far out weigh the learning curve. Not only on cad is it an accurate way to tell all conflicts.
the drawings for the builders are a lot easier to understand because you can drop a table on there and will tell the builder what parts need to be cut such as length, width, hieght, material, angle cut. Droping many views of the weldment are simple to so the builder can visualize it also. It is easy to customize to fit your needs. I would strongly recommend using it
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 01-02-2013, 04:33
Or 2230's Avatar
I agree with every single word, but when you start making sheet metal chasis and robot, you barely use weldments and you start using the sheet metal option
2011 IS finalists
Unread 01-02-2013, 10:29
Chris is me's Avatar
AKA: Pinecone
Weldments are really handy if you take the time to set up all your extrusion in advance. 80/20, 2x1 tube, whatever - it's a really quick way to lay out a frame and get a cut list for several construction methods.
Unread 01-02-2013, 10:59
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We CAD the entire robot, but we shell rather than extrude the box aluminum (etc). We've never used weldments, but I wouldn't mind learning what they're useful for. I'd particularly love to know if there's a way to predict the tendency for a frame to warp in a certain direction if a weld is placed on one corner vs. another.
I generally spend a few hours taking CAD models and making dimensioned drawings for the assembly. It's pretty straightforward: 1. Conjoined edges are welded at the welder's discretion (he knows more about strong welds than I do) and 2. Don't weld over holes.
GitHub
Unread 01-02-2013, 15:00
I know that there is stress analysis but that wont tell you where to weld or how it will warp. Although that more comes down to who is building the frame. I say its not hard to weld its hard to manufacture. Your welder needs to know to clamp down as much as he can and clamp braces across corners to keep it square. I would say problems with warping would be solve easier during building.
