Go to Post I don't think [Amanda] will have any trouble with Needel or the Kelsos but... I can understand Grady and we do have visible evidence of the menace that is Jessica Boucher. (just ask Billfred) - Al Skierkiewicz [more]
Unread 14-01-2013, 08:04
huurrpaderp's Avatar
huurrpaderp huurrpaderp is offline
AKA: Marcel Karczewski
FRC #1997 (Stag Robotics)
huurrpaderp is an unknown quantity at this point
What kind of shooter is your team using?
I am currently prototyping a liner belt shooter with little success and was wondering what kind of shooter you and your team have decided on or had the best results with?
Unread 14-01-2013, 09:30
ttldomination's Avatar
Sunny
Re: What kind of shooter is your team using?
Search is your friend. Really.
However, to address your prototype directly, in theory, it should work. About 6"-8" of belting leading up to the shooting wheel. What kind of results are you seeing?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 14-01-2013, 09:45
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
we finished protoyping last saturday (1/12/13) we came up with the shooter where a disk enters one side rotates around a wheel and shoots out its a half circle shooter which what seems like most teams will end up picking
Unread 14-01-2013, 14:01
Well currently we have three prototypes in the works. My belt shooter, a curved 90deg shooter, and a tomahawk style thing... We are not entirely sure what its supposed to do but whatever. My belt shooter is showing promise but need some calibration and adjustments, hopefully this will be completed today. The 90deg curved shooter is, so far, the best design having reached distances of up to 7ft... We AIM to choose the final shooter tomorrow.
Unread 14-01-2013, 16:39
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Linear one wheeled shooter.
https://kusha.me
Unread 14-01-2013, 16:58
We were apprehensive about this type of shooter since the disc would only be in contact with the wheel for a moment, leading to less time for acceleration therefore less consistent shots... What results did you get?
Unread 14-01-2013, 17:14
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
How are you measureing your distance? A straight shot, angled upward, how high off the ground?
Im curious (and you should reconsider the linear shooter) because I literally threw together a two wheeled linear shooter in 30 minutes and it shot at least 15 ft.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 14-01-2013, 17:18
Hmm, well we measured our belt and curved shooters at some 25deg up and flat. Maybe I will see if anyone is up for the task of testing a linear wheel shooter, but let me guess, you used pneumatic wheels right?
Unread 14-01-2013, 17:23
dellagd's Avatar
AKA: Griffin D
Yes (Well, psudo-pneumatic) Having the wheels flex makes a big difference. From "not working at all" to "works great". My measurements were from 3 ft off the ground at 0 degrees
Unread 14-01-2013, 17:28
Yes. Having the wheels flex makes a big difference. From "not working at all" to "works great". My measurements were from 3 ft off the ground at 0 degrees
Yea, I have been pressuring our mentor to get those wheels but for some reason he cant. But I think we may see a fix by adding some stiff rubber tubing(or whatever works) to the outer wall instead of having the wheel.
Unread 14-01-2013, 18:33
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
We are planning on a 2 wheel linear shooter with pneumatic wheels. Essentially the robot in 3 days shooter, except harder and faster. Ideally the disk will come out at about 25-30 m/s.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 14-01-2013, 22:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We don't know for sure, but today we got our 3rd or 4th iteration of the prototype working, with a curved shooter going thru about 90 degrees, with a 6" wedgetop tread wheel driven by a CIM and geared up in speed about 30%. It shot around 30 feet to about 6ft height (shooter on the ground), shooter angled up maybe 15 degrees. I think we'll probably go with this, the neat thing is with the way the thing is set up with sprockets and chain, we can change the ratio to get about any speed we want from 2000 to 8000 rpm or so at the wheel.
Unread 14-01-2013, 23:45
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Thumbs up Re: What kind of shooter is your team using?
We are doing basically the same thing. So far, it's working great, and shoots very far (not sure of exact measurements)
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 14-01-2013, 23:54
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
None.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 15-01-2013, 00:26
dellagd's Avatar
AKA: Griffin D
Originally Posted by Djur View Post
None.
Nice. Single function bots are always cool.
