Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 14-01-2013, 18:57
matthewkennedy matthewkennedy is offline
FRC #1294 (Top Gun)
matthewkennedy is an unknown quantity at this point
Wind River FIRST Menu Missing
I have a problem. I installed WindRiver from the 2013 DVDs, and then installed the workbench update from FIRST Forge. I have a robot project, it builds, properly runs/debugs on the cRIO. I was looking through the tutorials, I came across the fact that there should be a "FIRST" menu between "Run" and "Window". No such window exists on my machine, and thus I can't deploy code as startup to our cRIO.
It seems like all of the files got copied by the workbench update installer, but something didn't get installed properly. As I said, all of WPIlib is present, and all of the project templates are present. What'd I do wrong?
I'm on Windows 8 Pro 64-bit, if it helps.
Thanks in advance for any help!
Unread 14-01-2013, 19:54
Re: Wind River FIRST Menu Missing
I've seen people complain of the missing menu and then later report that it appears properly after a reboot. Did you try that?
Unread 14-01-2013, 19:56
FRC #1294 (Top Gun)
Yep, I have. It's been about a week since I installed all of the tools, and when I did I went with the full meal deal (full LabVIEW + WindRiver + FRC Utils). I've probably rebooted 3 times since, to no avail.
-Matthew
"The future is already here—it's just not very evenly distributed"
-William Gibson
Unread 14-01-2013, 22:59
KJGreen's Avatar
KJGreen KJGreen is offline
Team Captain
FRC #4237 (Lance-A-Bot)
KJGreen is an unknown quantity at this point
Have you run the 2013 Windriver Update? That was a problem for my team when we switched from Labview to C++.
Link: http://firstforge.wpi.edu/sf/frs/do/...A3E49D1D64308B
Unread 16-01-2013, 05:38
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Did you install all the updates?
Unread 16-01-2013, 10:57
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Did you install this:
http://firstforge.wpi.edu/sf/frs/do/...update_for_c_0
Unread 16-01-2013, 11:15
FRC #1294 (Top Gun)
Originally Posted by DjScribbles View Post
Yep. As I said, I have all of the WPIlib stuff, and robot projects build and deploy properly. Everything works BUT the FIRST menu.
-Matthew
-William Gibson
