Go to Post The only odd part about this competition is that rather than further convince me that I want to be an engineer, it did the converse... I want to be a teacher. - pauluffel [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
  #241   Spotlight this post!
Unread 14-01-2013, 18:05
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: Climbing Mechanism Ideas
Originally Posted by dellagd View Post
Our team has had a long running joke of building a "Rave"-bot for competition.
You've made my day.
And of course:
IMAGE REDACTED[/IMG]
Of course, and before going to Ramp Riot, where we brought an off-season project robot, our auton was set to spin in circles and play Gangnam Style from the driverstation while flashing LEDs
Unfortunately we had to change it to actually do something, though
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
  #242   Spotlight this post!
Unread 14-01-2013, 19:43
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Originally Posted by enigmatic View Post
We have an idea for a climber that will go up to the third level and then dump four colored discs in. We would score fifty points everytime, but there is resistance from members of the team because 1)we do not have a pyramid to test it on yet, making it difficult to do and 2) they believe we can score more points shooting. The reason for the disconnect is differing beliefs on how accurate shooters are going to be. Those who want a shooter believe at least 75%, but those who want a climber think it will be much lower than this.
Solid idea, don't forget to consider using one mechanism for multiple tasks. For example, you would make your alliance value much higher if you used your frisbee dumper to score 3 frisbees in the low goal during auto and continuing to score there or play defense during the game.
That would help offset the some of the negatives that come with this robot idea...
Originally Posted by RRLedford
The flipping or "rolling" up the corner edge with alternating short grip arms is how we are prototyping to go up the pyramid. Our style of gripper will not need to squeeze hard or damage the power coated tubes. The angle formed by the intersecting horizontal tubes is how/where we will grip, avoiding the slope tube entirely.
We will not drive; only shoot 2or 3 in autonomous. We may hoist others up, if we can keep hoist near enough to level rungs to have partner(s) bump them on the way up. They may have to extend some to snag our hook, since we can only lower it so much, but even if we only pull them up to the 20 pt. level, that is a nice bonus for a no driving bot to make.
-Dick Ledford
good luck to both teams, I would certainly consider either of your robots for my alliance!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Last edited by cmrnpizzo14 : 14-01-2013 at 19:43. Reason: deleting irrelevant information
  #243   Spotlight this post!
Unread 15-01-2013, 13:18
thmeans06 thmeans06 is offline
Drive Coach, IT Support, Mentor
FRC #0066
thmeans06 is an unknown quantity at this point
A lot of you guys are mentioning the 54" cylinder, which is great. However, don't forget about the max frame perimeter of 112"! A 30" square bot would be at 120"!
  #244   Spotlight this post!
Unread 15-01-2013, 14:04
enigmatic enigmatic is offline
FRC #2075
enigmatic is an unknown quantity at this point
We would potentially be able to shoot two in during auton, but that is about it. We would make sure to climb the pyramid early so as to make sure that we have time to gt up, otherwise we lose all of our points. So depending on how quickly we will be able to make it up, we might not play much defense.
  #245   Spotlight this post!
Unread 15-01-2013, 14:38
run the trap!!!
Team Role: Human Player
Originally Posted by RRLedford View Post
We will be able to grasp next higher level BEFORE releasing from one below. We will not tip or swivel around laterally, because our grasp mechanism will bridge across the two intersecting horizontal tubes, yet avoid contacting the slope tube.
The robot will be kind of vertically notched so it can straddle the corner edge tube at match start, allowing center of mass to be starting nearer to the initial gripping points.
-Dick Ledford
Now add to that a wheel which extends underneath the robot to prop it against the bar while reaching for the next level and we are considering the same design. We've even prototyped a mechanism which successfully climbed the pyramid unweighted. Trying to fit it into the cylinder is proving to be very difficult. If used, the enormity of the mechanism will force us to sacrifice a lot of our disc-shooter-goal scoring ability, which some of our team is strongly against.
When you start to CAD these designs one thing becomes apparent: either you focus on the climb, or you focus on the discs. Doing both well: nearly impossible.
Personally, I really like the 50 pt climb and dump strategy.
The advantage in my mind is that it allows you to score all of your points really fast and lets your team focus on perfecting a repeatable task.
If you're robot is only designed to climb and dump, you can spend the rest of the match playing defense. Essentially, you are forcing the other alliance to score 50+ pts under heavy D.... or.... beat you up the pyramid (which is unlikely if you have optimized your robot for this strategy).
If you focus on scoring discs. You need to be better at scoring discs than anyone else to win. There will be lots of bots scoring discs and you will need to outscore them. Very few will attempt the 50 pt strategy.
-Philip J. Fry
  #246   Spotlight this post!
Unread 16-01-2013, 10:24
FRC #2075
If you focus on scoring discs. You need to be better at scoring discs than anyone else to win. There will be lots of bots scoring discs and you will need to outscore them. Very few will attempt the 50 pt strategy.[/quote]
My thoughts exactly. We have others on our team who do not like the idea though.
  #247   Spotlight this post!
Unread 16-01-2013, 10:45
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
~snip~
What makes you say that?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #248   Spotlight this post!
Unread 01-04-2013, 06:45
JOClarke's Avatar
JOClarke JOClarke is offline
AKA: Chainsaw
FRC #0384 (Sparky)
JOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to all
I know this thread has been dormant for a while, but Sparky is trying to lighten our bot with switching our super shifter climbing mechanism to a tough box 3 stage. Does anybody have experience with this transmission? We are at a fork in the road try this and find the bugs or lighten the super shifter. Video of us climbing at the shop: http://www.youtube.com/watch?v=G8iIy...ature=youtu.be
Never stop thinking! It all begins with a spark! Growing up in a FIRST World!
