Go to Post Getting your questions answered is what the big thick manual is for....GO READ. - Dorienne [more]
Unread 14-01-2013, 20:02
eklaw eklaw is offline
eklaw is an unknown quantity at this point
Gearing up two cims?
Are there any gear boxes that allow to gear UP two cims to something between 1:3 and 1:4? Preferably single stage. Thanks!
Unread 14-01-2013, 20:30
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Gearing up two cims?
Not a gear box, but it can easily be done with chain (though thats a VERY fast output.)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 14-01-2013, 20:32
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is online now
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
MODULOX!
In all seriousness, Its what we used in Robot in 3 days. Worked fantastically.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
I'd be curious to know what you want to do with this, if you don't mind sharing.
Unread 14-01-2013, 20:34
Originally Posted by Andrew Remmers View Post
MODULOX!
- Andrew
Hey Andrew,
Since you're reading this thread, maybe you could give a definitive answer to a question that's been bouncing around:
What CIM operating speed did you finally settle on for your shooter, and what speed control algorithm did you use?
Unread 14-01-2013, 20:43
We're looking at using 2" belt pulleys with belts around them as a linear shooter and want to use 2 mini cims to augment our max output speed
Unread 14-01-2013, 20:50
Chris is me's Avatar
AKA: Pinecone
Honestly, if you are using such a small pulley, you could try something with a small (or no) reduction off of a faster motor like an FP or RS-550. The power difference isn't too noticeable in a flywheel and you will have a less frustrating time designing your shooter.
Unread 14-01-2013, 22:31
dtengineering's Avatar
AKA: Jason Brett
Yeah, I'd definitely recommend considering gearing down an FP (or similar) rather than gearing up a CIM.
We used a single FP with a 4:1 or 5:1 banebots planetary to shoot nerf balls about 30' back in 2006. So long as you keep them moving at a decent RPM most of the time they don't overheat.
Jason
Unread 14-01-2013, 22:40
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Jason
Interestingly enough, the FP motors aren't legal this year. New miniCIM and BAG motors make up for them though.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-01-2013, 08:31
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
The Banebots RS-550 is very nearly a drop-in replacement for the Fisher Price motor, with the exception of the output shaft not being knurled, and the motor having a little less power.
In Logomotion 2011, we drove our entire arm off a single Banebots RS-550 motor, appropriately geared down (about 750:1).
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 15-01-2013, 09:21
AKA: Andrew Remmers
Hey Andrew,
I'd have to say that I wasn't there for when the robot was programmed so I don't know what kind of speed control algorithm was used. However we did have a CIM that was operating less than optimal. It was geared up and I would guess the speed was closer to around 6-7k rpm. With the final shooter wheel running at about 8-9k rpm (perhaps even faster). I honestly don't remember the gear ratios but this was the estimated speed when we built it.
- Andrew
Unread 15-01-2013, 11:34
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
If you're still looking at using a CIM, AndyMark is working on a product called the spin box that should be available in the next few weeks that is designed for gearing up CIMs. Andy and I discussed it over lunch
Unread 15-01-2013, 21:36
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Do you happen to know if this SpinBox has a shaft for an encoder?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
