Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Unread 13-01-2013, 23:18
arthurlockman's Avatar
arthurlockman arthurlockman is offline
Team Captain
FRC #0172 (Northern Force)
arthurlockman is an unknown quantity at this point
Send a message via AIM to arthurlockman
Camera Placement
So this year there's a heated debate going on among some of our team members as to where the camera should go on the robot. I believe that it would be best to have it pointed in the same direction as the shooter, and follow it if it moves Some of my other teammates however believe it would be better to put the camera on its own rotating gimbal, Separate from the shooter entirely. Thoughts on this? What are other teams doing?
Thanks!
Arthur Lockman
Twitter: @arthurlockman
a.rthr.me
Unread 13-01-2013, 23:30
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Camera Placement
Thanks!
I would assume having the camera fixed to the shooter would help with aiming shots. Unless there is a significant advantage to having it point elsewhere, keep it fixed on the shooter. Drivers rarely look at the camera feed when driving. I know our driver only used it to double check that we were aligned before shooting last year.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 13-01-2013, 23:42
Putting the camera on a rotating turret sounds like a good idea, but any sort of lag time in either receiving the image or processing it will make it hard to implement a good aiming strategy. If the camera is on a relatively stationary platform you can use it to determine the desired turret direction, then use simple position feedback like a potentiometer to aim the turret quickly.
Unread 14-01-2013, 00:30
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Put it on the shooter locked into place. You can get a pretty good idea of what the robot is doing by looking at it -- less so for figuring out where it's aiming. That's where you'll get the most benefit out of it.
We'll try to use 2 (bandwidth testing will answer the question of whether that's realistic) because we're planning to be able to pick up from the floor (another difficult task to do from the driver station pov).
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 14-01-2013, 20:54
Team Captain
Thanks, guys. I'm the driver, and you're right, I seldom look at it. We're thinking of using a raspberry pi to do our image processing, so lag shouldn't be so much of an issue. But keeping it on the shooter in a fixed place was my feeling, I'll forward your thoughts to the rest of my team.
Arthur Lockman
a.rthr.me
