Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 14-01-2013, 20:22
keneajer's Avatar
keneajer keneajer is offline
AKA: Jerome (JJ) Kenealy
FRC #1091 (Oriole Assault)
keneajer is an unknown quantity at this point
Pit Flooring
Our team is looking at the opinon of putting some type of flooring in our pit area. Where looking at interlocking drainage floor tile or foams tiles.
Has your team done this in the past? What type of tile?
What are the pro's and con's of having any kind of flooring in the pit area?
FRC
Team 1091 - Hartford Union High School : Student Media Lead - 2005-2008
Team 1091 - Hartford Union High School : Mentor - 2008 - Present
Wisconsin Regional Volunteer : 2012 Field Repair & Reset
FLL
Team 740 - Oriole Light : Mentor - 2009
Team 3483 - Erin Energy Force : Mentor - 2010
Team 2162 - Oriole Light : Mentor - 2010
Unread 14-01-2013, 20:33
nitneylion452's Avatar
AKA: Joe Lee
Re: Pit Flooring
Just remember that any kind of flooring you bring in to the pits must remain entirely within your pit area. Not all pits will be a 10x10 square. They can be as small as 8x8 and some venues will not even give you a square! We had this happen to us with a neighbor bringing in some flooring, but the pits were 9x11 (WxL), so their flooring hung over into our pit which was a bit of a nuisance.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 14-01-2013, 20:34
Re: Pit Flooring
We used sections of 2' by 2' foam flooring for a few years. It's okay, but it's hard to keep clean and isn't very friendly for toolboxes, workbenches, or robot carts. The last couple of years we've used a square of old field carpet, and that works great.
Unread 14-01-2013, 20:36
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Pit Flooring
We use foam tiles. They can get metal shavings in them, so you'll most likely need a vacuum with you in the pit.
Unread 14-01-2013, 20:42
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
Re: Pit Flooring
We use the interlocking 2x2 foot square foam pads that you can get at the hardware store. You will need 25 of them for a 10 x 10 pit. They typically come in packs of six, so we loan the extra ones to the pit admin people so they don't have to stand on the hard floor all day.
Pros, they make being in the pit much more comfortable and robot inspectors LOVE them when they have to get down on the ground to check out your bot.
Cons, they are a bit bulky to transport, and you have to put them down before you assemble your pit and bring all your stuff in, or you have to move everything around to get them under all your stuff which can be a pain.
Unread 14-01-2013, 20:59
ttldomination's Avatar
Sunny
Re: Pit Flooring
I'll provide some historical experience here.
On my old team, we used the foam tiles that the FTC/VEX programs generally default to. Because we host an event, we have a ton laying around.
We generally put out an 8'x8' square. This is just we can put the tools and tables and cabinets on the concrete (or whatever).
Do be careful here. It's just foam, so this means that things like carts, driving robots, etc. leave impressions and these pieces loose chunks. I'd recommend having two sets just so you can pull from one.
A little while ago, I remember that a team was handing out strips of what felt like the semi-hard spongey material that they make running tracks out of. It was soft enough to kneel down onto, but it seemed like it'd be hard enough to withstand 90% of the FRC experience. Anyone know of this magic material?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 14-01-2013, 21:37
kellymc kellymc is offline
FRC #0766 (Bears)
kellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to behold
Re: Pit Flooring
Take a look at racedeck. They have both smooth and textured options. All the tiles snap together and are rated to have cars driven on them. You can create patterns with the color options they offer.
Kelly
Unread 14-01-2013, 21:40
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Re: Pit Flooring
We've used interlocking foam squares for 4 or 5 years and they're great. I picked them up at Canadian Tire or Home Despot in a pack of 8. Each tile is about 24" and the package came with 2" wide edges which we pitched. We arrange them in a 3 x 3 square with a hole in the middle where the swarf etc collect. We don't bother putting them under the bench or tool carts. Things don't bounce or roll away and it's a lot easier on the feet, legs and knees after a long couple of days. We keep them in a garbage bag for storage and carrying. Highly recommended.
Unread 14-01-2013, 23:01
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Pit Flooring
My old team used foam tiles, and they were very nice and helped with the fatigue that you get from standing on concrete all day (may be a good pitch to the UL safety guys). We would only place them in the center where we walk around the robot cart, where the toolboxes and table were had no foam under them and this worked well. The cart would tend to bunch up the foam if you tried to turn the cart on the foam so the cart was pushed in and out in a straight line.
A word of caution on this foam flooring, it caused a significant increase in the amount of static buildup that we experienced, so do be careful that you do not zap your electronics.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 14-01-2013, 23:22
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Pit Flooring
We use carpet. It makes it easier to test things on the floor of the pit without going and finding a carpeted practice area, in games where the floor is important (we used it a lot in 2010 and a bit in 2012 to tune ball pickup mechanisms).
Kettering Motorsports
Unread 15-01-2013, 00:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Pit Flooring
We've been very happy with Garage Deck cointop tiles from BigFloors.com. It's also good for outdoor demos on grass. We have 10x14 of it and keep it in 2x2 foot squares.
