Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 14-01-2013, 21:03
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Pressure Switch
Right now I have a compressor continuously running. How do I add a pressure switch so it shuts off at a certain psi. This is what my code looks like so far (ignore the Digital Modules). Thanks!
Allons-y!
Unread 14-01-2013, 21:05
FRC #4665
Re: Pressure Switch
Here is my code.
Unread 14-01-2013, 21:08
Re: Pressure Switch
A pressure switch should be wired up to DIO 1 as your code specifies.
One wire to signal, the other wire to ground.
This switch is preset to turn off around 115psi and back on at 95psi.
Unread 14-01-2013, 21:11
FRC #4665
Re: Pressure Switch
Okay cool, so I wouldn't have to add in any code, just wire the switch to DIO 1?
Unread 14-01-2013, 21:14
Re: Pressure Switch
Yep, your code looks complete.
Unread 14-01-2013, 21:20
FRC #4665
Re: Pressure Switch
Thank you, you have really been a great help (with all of these questions I've been asking). I really appreciate it!
Unread 14-01-2013, 21:25
Re: Pressure Switch
Does the pressure switch calibration need to be checked and adjusted this year?
Unread 14-01-2013, 21:51
Re: Pressure Switch
There is no adjustment on the pressure switch.
You might be thinking of the pressure relief valve which has to be adjusted to 125psi.
Unread 14-01-2013, 22:41
Re: Pressure Switch
Yeah, my bad. That's what I was thinking of.
Unread 19-01-2013, 02:55
FRC #4665
Re: Pressure Switch
The problem was a bad connection between the sidecar and the spike. All is well now. Thank you everyone.
