Re: Pressure Switch
A pressure switch should be wired up to DIO 1 as your code specifies.
One wire to signal, the other wire to ground. This switch is preset to turn off around 115psi and back on at 95psi. ![]() Last edited by Mark McLeod : 14-01-2013 at 21:11. |
Re: Pressure Switch
Re: Pressure Switch
Yep, your code looks complete.
Re: Pressure Switch
Thank you, you have really been a great help (with all of these questions I've been asking). I really appreciate it!
Re: Pressure Switch
Does the pressure switch calibration need to be checked and adjusted this year? |
Re: Pressure Switch
There is no adjustment on the pressure switch.
You might be thinking of the pressure relief valve which has to be adjusted to 125psi. |
#7
Re: Pressure Switch
Re: Pressure Switch
The problem was a bad connection between the sidecar and the spike. All is well now. Thank you everyone.
