Go to Post the truth is that a 'bot is only as complicated as you make it. - RogerR [more]
Unread 14-01-2013, 21:44
tinybob20 tinybob20 is offline
AKA: Jeremy
FRC #1559 (DevilTech)
tinybob20 is an unknown quantity at this point
Speed Controllers are Confused
We've been having this weird error with victors. When I compile code on my laptop, which changes the victor from on to off based on the press of a button, the victor's light changes from solid red(when the victor is set to 0) to the LED being off(When the victor is set to 1). We compiled the same code on a different laptop, and we got it to work as it should. What I'm asking is if anyone has had the same problem, and if they found a work-around or fix.
