Re: Pressure Switch
There is no adjustment on the pressure switch.
You might be thinking of the pressure relief valve which has to be adjusted to 125psi. |
Re: Pressure Switch
Re: Pressure Switch
The problem was a bad connection between the sidecar and the spike. All is well now. Thank you everyone.
