Go to Post HAH! What else am I supposed to do on a weekend? Sleep? - Michael Hill [more]
Unread 14-01-2013, 22:28
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Utilizing the Smart Dashboard
Originally Posted by F22Rapture View Post
Check out the doc named "Testing Commands" from here:
http://wpilib.screenstepslive.com/s/3120/m/7932
and also here:
http://wpilib.screenstepslive.com/s/...-robot-program
It's a way of sending persistent values to the robot, as you were talking about in #2. The values are saved to the cRIO's flash memory and should remain there across reboots. I've never used it, so I don't know about the string limitation.
Yes, I believe you can do that using live window mode, or else you can create a new extension to do so (possibly using some source code from live window).
Not hooked up to a bot ATM, so cant test #2-3. Any documentation on #5 would be good.... cant find anything good in live window mode. For #1, so is there no way to do it without Commands? I do not like the Command-based robot system
