Go to Post Great teams derive from great mentors. - Barry Bonzack [more]
Unread 14-01-2013, 22:06
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
best materiel for disk transport
We're looking at some sort of elevator for moving the disks from a scoop to a hopper. We'd then push the disks from the hopper to the shooter. We've got a scoop designed to get the disks off the floor but we're not finding an materiel that's sticky enough create sufficient friction to be able to lift the disks. Any thoughts out there on how to improve the friction?
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
Unread 14-01-2013, 22:42
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: best materiel for disk transport
You might want to check out the suction cup tape or grip tape from Inventables.
https://www.inventables.com/technolo...ction-cup-tape
https://www.inventables.com/technologies/grip-tape
There's a product donation voucher (or equivalent) for them in the Kit of Parts. Lots of neat stuff there.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 15-01-2013, 02:47
varunv varunv is offline
AKA: Varun
FRC #0948 (NRG (Energy))
varunv is an unknown quantity at this point
is it a vertical climb or is it slightly angled? because the Force of Friction can be reduced drastically because the Normal force would be canceled out if it was angled.
2013 Seattle Regional Winners
2013 Seattle Regional Engineering Inspiration Award
2014 Auburn District Chairman's Winner
Unread 15-01-2013, 09:06
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Try non-slip mat or what we call 'carpet grip' here. http://www.cakesaroundtown.com.au/ca...tting-BLUE.jpg In Australia you can find it at all discount variety stores. I'm not sure what you'd call them in the US, but it's a fairly cheap, easy to use, versatile and sticky material.
By lifting the discs do you mean pickup off the floor or convey along a surface?
If you want to convey off the surface, you can use some timing belt similar to what you received in your kit, but turn it inside out and experiment with the teeth to come up with a system that works.
Unread 15-01-2013, 22:40
FRC #3512
Our initial thought is to use a platform to scoop up the disks and then use a transport to lift them up to a hopper. Our current approach has about a 33" tall robot. That means we would have to go full vertical for roughly the full height.
Scott McLean
Team role: mentor
