Go to Post Given a choice between giving a man a fish and teaching him to fish, you always want to teach them to fish. But sometimes that involves showing him how to put the worm on the hook first. - dlavery [more]
Unread 14-01-2013, 21:43
gobrewcrew95 gobrewcrew95 is offline
FRC #2506
gobrewcrew95 is an unknown quantity at this point
3rd level climb even possible?
My question is exactly as stated above.
Is a third level climb even possible?
Yes, it is achievable right away at the start of the match, but what about at the END of the match?
After your robot has driven around the field and taken shots at the goal, how much battery power would you even have left?
Then, is it enough to get your robot at least 60", most likely more, to get the third level climbing points?
If anyone could please answer the question(s), that'd be great. Feel free to leave a comment or concern related to this topic too.
Unread 14-01-2013, 21:45
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: 3rd level climb even possible?
Yes it is possible.
You will see it happen in the next 6 to 8 weeks.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 14-01-2013, 21:50
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Then, is it enough to get your robot at least 90", most likely more, to get the third level climbing points?
We did some math and we calculated that we can climb at a rate of 2ft per second with 2 cims driving our climber. Of course we are probably going to gear it down because we don't want it to climb that fast. If ours works, we can probably climb in roughly 10-15 seconds. Especially if you have your climbing procedure automated.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Dr. Shocker's Avatar
Dr. Shocker Dr. Shocker is offline
Alumn
FRC #1126 (SparX)
Dr. Shocker is on a distinguished road
I would just like to point out that you do not need to get 90" off the ground, the lowest part of your robot just needs to be ABOVE 60.75" or so off the ground. (.75" for the radius of the pipe) Whether or not this makes it seem more or less possible is up to you.
Unread 14-01-2013, 21:52
FRC #2506
You're correct, my bad. Change has been made.
Unread 14-01-2013, 22:24
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
We've run our battery off of a single charge for well over a half an hour driving around, shooting, ramming, and balancing while practicing last year, so I don't see power as being too much of an issue. That is, as long as you have enough batteries and enough chargers to have a full charge every match, you should be fine.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 14-01-2013, 22:28
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
I might add that using pneumatics completely circumvents the problem of battery drop.
Pneumatics is also very powerful and will hold after power-down, unlike some motor mechanisms that have no mechanical stop.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 14-01-2013, 22:29
Andrew Lawrence
Posts: n/a
Anything's possible.
Unread 14-01-2013, 23:09
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Its quite possible. I dont think the GDC would issue an impossible challenge.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 14-01-2013, 23:31
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
How would you implement a pneumatic climber? I could definitely see using pneumatics to actuate claws, but aren't they mostly useful for pushing and not pulling, as the majority of the movement in the climb would be?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 14-01-2013, 23:37
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Arrow Re: 3rd level climb even possible?
When your team gets your climber working well, could you post a video of it climbing? I'm interested in seeing other teams' approaches to the pyramid
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 14-01-2013, 23:40
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Implying that it is impossible is not a very productive use of time. Although some things are impossible, this is not one of them. It is simply really, really hard.
We will not see many 30pt climbs this season. A shooter is a lot easier to build. But that is not to say that you should not consider trying to build a climber.
-Plutarch
Unread 15-01-2013, 00:28
dellagd's Avatar
AKA: Griffin D
Honestly Im really curious as to how successful teams will be with the 30 pt climb this year. I simply dont know.
Unread 15-01-2013, 09:28
FRC #2506
Of course I believe its possible, but few teams will be able to. I see part of the challenge this year is to either sacrifice a high climb and be a good shooter, or sacrifice shooting and be a dedicated 3rd level climber.
My team has spent awhile designing and coming up with ways to climb and we even have a design that would work for level 3. But then one of our mentors pointed out how much battery power it would take to get to the 3rd level. So we actually designed two climbers. One for a quick level one climb and a 3rd level climb if we want to take the risk.
Unread 15-01-2013, 09:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm really hoping that this year we'll see the first triple-hybrid mechanism -- one that uses motors, pneumatics AND constant-force springs to move up the pyramid. It's the perfect year for it, and totally removes the issues with battery drain. Essentially the motor must overcome the force of the spring to put a latch in place, then the motor reverses while the cylinder kicks in and all 3 force-providing mechanisms pull the robot up.
I think a 30-pt climb is possible, but the sacrifice for 99% of the teams needs to be evaluated on a team-by-team basis (I think only 1% of teams are even capable of doing a 30-pt climb while also being good at everything else). For us, it just isn't there (sad face).
GitHub
