Go to Post Last I looked, FIRST wasn't an acronym for inspiration and recognition of robots. It was and is an acronym for inspiration and recognition of science and technology. - JaneYoung [more]
Unread 13-01-2013, 21:42
Re: Andymark Pneumatic wheel problems
Originally Posted by Wiifi View Post
We tested our pneumatic wheel at 60% speed today, launching between the wheel and our wood prototype base. We experienced approximately the same range/speed as the Robot in Three Days robot.
A number of questions immediately spring to mind:
1) what does "60% speed" mean? 60% of the motor's rated free speed (in which case how did you measure the speed)? 60% command to your motor controller? 7.2 volts from a DC power supply? or something else?
2) what motor were you using, and what gear ratio?
3) you said "wheel" and not "wheels". Is this a single-wheel linear shooter? or a curved chute shooter?
4) were you using the same model and size pneumatic tire as R3D? or something else?
5) how do you know the speed of the R3D shooter? I couldn't find that info anywhere. could you post a link please.
edit:
I just now saw your video. Whole lotta slippin' going on as the bee exits. Have you tried slowing down the wheel?
Unread 13-01-2013, 21:52
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
I uploaded a video of our shooter at 1000 frames/sec http://youtu.be/7dN1thFqr7k
Great video, thanks for posting.
What surprised me at first in your video, and in other slow motion videos of frisbee shooters is how little slip there is between the disc and the vertical surface opposite the wheel.
Has anyone done AB tests with and without friction material added on that surface? I don't think there would be much difference.
Graham.
Unread 13-01-2013, 21:53
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
edit:
1) 60% command to the motor controller, I can measure the voltage tomorrow.
2) CIM direct drive
3) See video http://youtu.be/7dN1thFqr7k
4) We used this wheel which I believe R3D used, I cannot confirm they did.
5) I do not know the speed, I was using the assumption from a previous poster.
The slipping is caused by not having enough tension between the wheel and the side of the arc. The wheel is as deflated as we could get it in this video. This prototype was designed for an 8" rubber wheel
so that is what caused the extra space. Tomorrow I am setting up my velocity reader, another mentor is modifying the wheel to be more effective (I don't specifically remember how) and we will be remounting the wheel closer to the arc.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 13-01-2013, 22:12
Measure the CIM current too, if you have a clamp-on ammeter... then you can estimate the wheel speed using the volts and amps.
Unread 13-01-2013, 22:50
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
We have ordered some of these wheels and they will be arriving on Tuesday. Couldn't find any information on this on the Andymark website, but what will we need to fill the tubes with air?
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 13-01-2013, 22:52
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
These typically come unassembled. So you will need to do all of the assembly of the components including airing the tubes up.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 13-01-2013, 22:54
AKA: Carl Springli
What will we need to fill the tubes with air though? Is it going to be exactly like filling a bike tire with air?
Unread 13-01-2013, 22:58
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Yes, if you have standard Schrader tubes on your bike.
http://en.wikipedia.org/wiki/Schrader_valve
Unread 13-01-2013, 23:40
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
I'll add it to my list.
Unread 14-01-2013, 08:32
These tires are not balanced as that is not needed in normal operation.
Unread 14-01-2013, 23:44
In today's Lunch with Andy episode, he mentioned adding weight to balance the valve stem.
Unread 14-01-2013, 23:48
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Originally Posted by PizzaBoxZombie View Post
As several other teams and IR3 have shown in various youtube videos, the pneumatic wheels from andymark are pretty decent shooting wheels. after recieving ours, however, we found that ours are out of balance/round. spinning at 5-6500 rpm they shake around a lot and can not achieve full potential speed.
we have since changed wheels for some more consistent and faster, but we were wondering if anyone else had tried to use them and found the same problems? and if anyone has, have you found a solution?
At first, we thought we had the same problem. We then strengthened the motor mount we made, and the shaking almost disappeared. Just tighten it up, or attach it better i guess ?
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 15-01-2013, 07:45
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
just wondering has anyone had a problem with the wheel braking under a high rpm because we ordered pneumatic wheels and we were testing with a placation wheel and the tread broke off the wheel so is it possible this can happen with the pneumatics wheels
Unread 15-01-2013, 08:33
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Here is what I for see as the problem. Lets take in consideration the pneumatic tire of a automobile. It spins usually 1500 rpm and is meant to travel at speeds 100mph. The rim of the tire is meant to seal at the bead just right and have a place where you can balance the tire. because not every rubber tire you get off the assembly line is the same one. Now lets look at the Andymark pneumatic wheels, They have a simple design with a rim a tube and the tire. teams are spinning these wheels at complete excess of what they were designed to do. these tires cant be balanced nor do they 100% seal to the bead. Now if a team were to just by the tire from andymark and scale down a CAD design of a real life rim and buy some weights from Napa or any other auto parts store. then you will get a properly balanced wheel.
Unread 15-01-2013, 08:34
Luke,
Let the centrifugal force be with you!
If you plan to use any wheel in a high RPM mode, you need to be sure that the surface (tread, tire, tube) are rated for that RPM. Spinning devices can have tremendous energy and when they self destruct they impart that energy to their surroundings, be that robot or human.
Carmen,
Automotive wheel weights need to be designed for the tire rim they will be used on to prevent them from escaping. Your 1500 RPM calculation is close to an average 15" wheel at max rated tire speed, which for most cars has already exceeded the point at which vehicle stability has been lost. If a team were to go down to the their local auto store and bought some of those weights, I am fairly certain they would be ejected from the wheel prior to full speed.
