Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Unread 15-01-2013, 00:41
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
High speed treaded wheel safety warning
Thought I would share a lesson learned the hard way. All of the posts and videos relating to prototype testing of wheel shooters being hand fed has prompted me to share the results of tread connection failure on an AndyMark custom wheel with traction tread attached in standard way by rivets...please, please consider the possible separation of tread that is not rated for some of the high speed tests many of us have been running...the result- I have a broken thumb and am going to lose my thumbnail. At least use a stick or other device to load your shooter when using wheels with attached treads!
Edit: I have contacted Team Support and asked them to pass the warning along. Hopefully we see it in the next blog or team blast since most exposure is occurring now during the development stage...
"A genius is just a talented person who does his homework" T. Edison
Unread 15-01-2013, 01:03
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Re: High speed treaded wheel safety warning
Thanks for the word of warning. Hope that heals up quick!
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 15-01-2013, 01:07
Ouch.
Thanks for the words of warning, Joe.
Thanks for the visual
Unread 15-01-2013, 01:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You got lucky. We had a very similar injury last season, except it was a custom 10" wheel at about 5k RPM and when the tread came off, it shot straight through 1/4" plywood and broke the student's finger. Lesson learned.
Unread 15-01-2013, 01:25
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
As always, Safety first, everything else second. I still get shivers whenever i remember the post about a mentor losing a finger in a drive train.
Never place your fingers within less than 3 inches of a moving part, especially one moving at very high speeds.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 15-01-2013, 01:37
AKA: Joe Barry
My thumb was probably 6 inches away and a flap of more than 6 inches of tread separated from the 6 inch wheel...that's my point-normal safety procedure might not protect you given the nature of many of these shooter wheels.
Unread 15-01-2013, 07:41
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
same thing happened to me yesterday we were testing with a placation wheel and the mount vibrated to much and as it was falling off a table i went to catch it but my finger went into the wheel cracking the nail in my pointer finger in half the wheel was spinning at 6k rpm by the way
Unread 15-01-2013, 07:50
AKA: noops
Oh my. wow.
Unread 15-01-2013, 08:39
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
The lesson that should be learned is a lot of these parts from andymark are not designed for high RPM use. take for example the axle we are using on our shooter mechanism it sticks up about 6 inches past the mounted wheel and the vibration effect at 5000 RPM causes it to wobble a quarter to a half inch.
Unread 15-01-2013, 08:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Ouch! Thank you for the warning....that's a tough lesson, and your sharing it is much appreciated.
Our shooter will get a pushing mechanism and guards on it before we fire it up again.
Unread 16-01-2013, 15:19
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
We had a similar issue a few days ago while testing a prototype. The tread was attached using aluminum rivets. We will be switching to steel rivets for high speed wheels as well as adding a guard.
Were you using steel or aluminum rivets?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 16-01-2013, 15:38
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Another point to add: If you are using a motor on a direct drive, use ball bearing assemblies RATED for greater than the RPM you will be seeing. Do not use a bushing at these RPMs. Main drive wheels can get away with less engineering due to the typically lower rpm.
There is no excuse for lack of proper thought when working with rotating assemblies. If your shaft is vibrating under load by itself, you are doing something wrong. Assess what you have and redesign. Rotating assemblies simply should not wobble or be out of balance freely spinning.
On last year's robot, we also added a safety cage in the unlikely event of a shooter wheel separation.
Just my thoughts.
Unread 17-01-2013, 16:46
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Thanks for posting the picture to remind us all that safety is not to be taken lightly.
I'd be worried about any wheel tread that's not designed for high speed use. The riveted ones are prime suspects, but I also suspect that the foam wheels may disintegrate. Granted, foam is safer than rivets, but still...
We have been preparing to run a shooter with the 8 inch AndyMark pneumatic wheelchair tires. I noticed that they are highly unbalanced due to the valve stem, so I'll be taking some time to correct that before firing it up. I'm not too worried about the tires themselves holding up to a couple thousand RPM, as they appear to use standard pneumatic tire construction. I am worried about someone's hand getting in the mechanism.
We'll also work on ensuring that nobody's in the line of spinning stuff.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 17-01-2013, 22:22
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
Talking Re: High speed treaded wheel safety warning
here is a picture of me after the 6 hour bus ride home from last years regional in Duluth, I got a little friendly with our shooter wheel whilst testing auton in the pit... it was spinning 2500 RPM. It happened all of a sudden and I calmly disabled the robot and said "THAT HURT LIKE A SON OF A B****" My head mentor turned around to tell me to watch my language when he realized my hand was covered in blood. I put my other hand on the table to brace myself and said "I think I'm gonna pass out" I looked down, saw blood squirt from the tip of my finger and woke up in another mentors lap. As I awoke seconds later, the AWESOME medical staff at the regional was there tending to my finger, I signaled for a freshman to grab my phone and I promptly update my Status "Ouch!" lol I hopped up, ran out to queue with a wrapped up finger, and we won our last qual. Got back home, the wound had been opened too long to stitch and it was broken in like 3 places. Its healed now, but there is still some scaring and my nail is weird. I will now have a reminder of my time with FRC FOREVER! lol
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 17-01-2013, 22:48
math311's Avatar
math311 math311 is offline
FRC #2077 (LaserBots)
math311 is an unknown quantity at this point
Nasty job on your finger, but you'll always have that memory of FIRST. My team has been fortunate enough to avoid major injuries. I got hit in the head with a soccer ball at high speed during Breakaway when we were practicing with our bot, and the turning control was brushed as someone moved their arm. But otherwise we have avoided anything huge.
