Go to Post Success to me is a feeling that is associated with achieving something you truly worked hard for; something that you can look at and say "That's my best work." - OneAngryDaisy [more]
Unread 15-01-2013, 01:17
Nymph808's Avatar
Nymph808 Nymph808 is offline
FRC #2443
Nymph808 is an unknown quantity at this point
D-Link Set up issues
So our team is facing an issue with setting up our D-Link.The problem is that we follow the getting started instructions, and after we finish we cant connect to our cRio. We have our router set up, and we know the D-Link is the issue.
Unread 15-01-2013, 01:34
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: D-Link Set up issues
Have you upgraded the D-Link to firmware 2.03 and flashed it using the FIRST-provided software?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 15-01-2013, 08:06
How do you know the D-Link is the issue? What exactly won't connect to the cRIO?
Did you set a WPA key on the router?
What is the IP address of your computer?
