Go to Post This is about more than building a robot, we cannot only do the fun things. If you are fully involved than you will be prepared to do anything in life. - Andy Brockway [more]
Unread 14-01-2013, 23:57
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Re: Picking frisbee off the floor prototype
Originally Posted by s_forbes View Post
The hopper is included in the video; the track will hold 4 frisbees and act as the 'hopper'.
So then I guess I meant to ask how will you get them from the hopper into the shooter?
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 15-01-2013, 08:14
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Originally Posted by JB987 View Post
Could be worth the effort if you hope to pick up 2 under the pyramid during auto, Fredi Nice prototype just the same! Have you tried the set up without bottom belts and just lexan bottom on long run portion of loader?
We could not get a high enough coefficient of friction, that does mean it can't be done with a different belt though
Faridodin "Fredi" Lajvardi KD7WKD
Unread 15-01-2013, 08:15
AKA: Ledge
Originally Posted by Andrew Lawrence View Post
How close to the ground are you?
I don't have the number with me now but I would venture to say about a 1/16 of an inch
Unread 15-01-2013, 08:21
AKA: Ledge
We are planning on having a pneumatic loader, pop them up about 4 inches, because the shooter will be right above the polycord track. A second piston will launch the frisbee int the the shooter wheels, we are using an inline shooter.
Unread 15-01-2013, 10:04
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
So what is your plan for the "bump". That 1/4" to 3/8" lip of carpet that goes around the pyramid. Are you planning to articulate your Polycarp lip and raise it or will you just avoid the pyramid?
Unread 15-01-2013, 10:42
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
If you were to move the front roller forward and the Lexan further back, so that the roller is the first thing to contact Frisbee, will this concept still work?
Or is it better with the Lexan hitting it first? Just wondering because i'm not sure how I should do mine.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 15-01-2013, 10:54
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Set up a similar model, with roller first and then add lexan extension on bottom so it contacts disks first and test to find out? This presumes you have components of course
"A genius is just a talented person who does his homework" T. Edison
Unread 15-01-2013, 10:57
AKA: Ledge
That might work....we were working within the constraints we had for our arm
Unread 15-01-2013, 14:17
Having components is the issue. With the teacher strike all of our gear is at the school.
2013-Present
2010-2013
Unread 15-01-2013, 22:19
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
Where can you buy that cord stuff at? Is it cheap?
Unread 15-01-2013, 22:40
DonRotolo's Avatar
Back to humble
FRC #0832
OK, so what if it could articulate a little upwards, and it rode on small "skis" that would guide it over the <1/2" 'bumps'?
Sorry, it's a problem and I have to try to solve it. I just can't help myself.
Unread 15-01-2013, 23:07
Rangel's Avatar
Rangel Rangel is offline
John Rangel
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
It might be able to. For when we start to climb we are going to have to articulate the grabber part so that it is out of the way. Could use the same device to get it over the bump. Or we can just nudge the arm up a bit when we get to those bumps.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
