Go to Post The question is like asking "Is it better to drive by looking at a map the whole time or by remembering where you want to go and watching the road instead?" - lukevanoort [more]
Unread 14-01-2013, 13:39
Luan Motta Luan Motta is offline
FRC #1772
Luan Motta is an unknown quantity at this point
Keep the engine speed
We want that the motor remains at the same speed all the time with encoder.
Maybe we need to use the PID controller.
How we will do this in java?
Unread 14-01-2013, 15:32
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: Keep the engine speed
Last year, we used a "Bang Bang" controller, which Mr. Ether helped us implement (though he got the idea from another member here, IIRC) for controlling our shooter wheel.
My C++ (similar enough to Java to help) source code from last year lives here:
https://github.com/TeamExcel/Project.../Robot2012.cpp
Lines 1063 and 1346 are most interesting for you.
The basic proposition is that a PID controller is overkill, or the wrong tool for the job; when you power the wheel, the RPM will increase, when you don't power the wheel, the RPM will decrease. Since you have direct control over what you want to change (speed of the wheel), you simply apply power when the wheel isn't going fast enough, and remove power once it is going fast enough; it won't continue going faster when you remove power, so you don't have to reduce power as you approach the setpoint (one of the features of a PID), and once you pass your setpoint removing power is the best way to reduce your speed (rather than applying power in the negative direction).
Our output to the motor uses a voltage ramp to prevent any big snap on/off actions (ie if the motor is off, quickly ramp up the voltage toward 100%, rather than jumping there instantly), other than that, it's "On" when too slow, and "Off" when too fast.
Make sure you are not in "brake" mode on your motor controller (a jumper on the Jaguar controls this).
Unread 14-01-2013, 15:37
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We had this working for our drive train last year, and we program in Java. If you send an e-mail to 2177@therobettes.com, I'll make sure our programmers send you a code sample of what we did!
2016: Lake Superior WFFA
Unread 14-01-2013, 19:40
AKA: Brad
#0190 ( Gompei and the Herd)
If you want to use the PIDController class for this, be sure to use the FeedFoward term. It is documented partway down this page:
http://wpilib.screenstepslive.com/s/...rs-pid-control
but basically, you need to give the motor a base value that is close the desired motor speed. The P, I, and D adjustments will be added to the FeedForward term in the calculations.
Brad
Brad Miller
Robotics Resource Center
Unread 14-01-2013, 20:15
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Is there a way to hook an encoder to the CIMs if we aren't using a gearbox?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 14-01-2013, 21:17
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I'm not sure of how one would do that (I'm not very mechanically minded), but there are other ways to measure the speed of a wheel. On our shooter last year we had a beam sensor which detected the spokes of the wheel instead of an encoder. It runs into some trouble at lower speeds, but the cRIO's counters are perfectly capable of measuring the speed of something like that
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 14-01-2013, 21:23
Did you ask the FPGA for the spoke count and then divide the change in spoke count by the elapsed time,
or
Did you ask the FPGA for the elapsed time (using the microtimer) between the last two counts ?
Unread 14-01-2013, 21:34
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
http://www.chiefdelphi.com/forums/sh...d.php?t=105679
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-01-2013, 00:30
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Brad
Happy to see a feed forward term was added to the PIDController class this year!
Unread 15-01-2013, 00:43
AKA: Ian Thompson
or
The latter (via GetPeriod()). The issue was that the FPGA declared the motor stalled below certain speeds. We considered the other method for a bit, but decided that it wasn't really necessary to implement since the problematic speeds were so slow that the ball wouldn't even get out of the shooter.
Unread 15-01-2013, 08:57
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A bang-bang controller tends to be limited in situations where your rotational inertia is not high. The result is an unstable speed that oscillates approximately just above your set point.
If you are using pneumatic wheels or something else with a reasonably high moment of inertia (I haven't done calculations to determine the cross over) then bang-bang is fine. Otherwise, you will probably want to look at PID. Or you can combine the two using a conditional to switch from bang-bang to PID when you are within a certain range of your setpoint.
Unread 15-01-2013, 09:43
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Last year, we controlled our shooter wheel using a gear tooth counter as a sensor and a PID function based on BradAMiller's PIDController class. We
overloaded the Calculate function in the class (if I remember correctly...don't have the code here) based on a vi of a PID method posted, here, on CD by Kevin Harrial of Team 2168. (We re-wrote it in C++) Without the speed control we measured ~5.0sec recovery time after shooting a ball. With the PID we reduced that to ~0.5sec. 10x improvement! With the closed loop control, the drive team could shoot fast with good repeatability. In addition to the gear tooth sensor, we also tried a TachGen. It worked great, but it put us over the robot cost limit.
I haven't looked at Brad's method for this year, but that addition of the FF is a good one!
Eric
Don't PANIC!
S. P. A. M.
Unread 15-01-2013, 09:54
You can make it work with lower inertia wheels with just a few extra lines of code.
Instead of banging between 0% and 100% when you're near the setpoint, reduce the amplitude of the banging.
To do this, you need to have an idea of what the nominal required voltage is at each setpoint speed you want to control.
For a simple example, let's say you want to control the speed at 3000 rpm and you've found it takes approx 60% of full voltage to do that.
Change your bang-bang code from this:
if (speed > 3000) bang 0%
else bang 100%
...to this:
if (speed > 3000 + 200) bang 0%
else if (speed > 3000) bang 60% - 20%
else if (speed > 3000 - 200) bang 60% + 20%
else bang 100%
The numbers above in bold black are your setpoint and your estimated voltage% at setpoint.
The numbers above in red are "tuning parameters".
Making the 20% number larger improves spinup recovery time. Making it smaller reduces the amplitude of oscillations. Don't make it too small or you'll have essentially open-loop operation.
Making the "200" number smaller improves spinup recovery time. If you make it too small the extra lines of code have no effect - you've essentially got 0-100% bang-bang.
Last edited by Ether : 15-01-2013 at 11:03. Reason: replaced narrative with pseudocode
Unread 15-01-2013, 16:35
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
What is the advantage of using the "bang-bang" method of speed control versus PID?
Better use of the motor power band perhaps?
Unread 15-01-2013, 16:43
If you've got enough inertia and can use the simple on/off logic, it requires no tuning and very little code.
Since the code is so simple, you can run it at higher speed without sucking up too much processing time.
It has the fastest spin-up and recovery time.
