Go to Post lets get FIRST in every home around the world, and a robot in every school. - Rohith Surampudi [more]
Unread 15-01-2013, 12:10
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
Re: G04
as a kind of follow up to everything about the BELAY system; it's not meant to aid you in removing your robot, it's meant to ensure that the robot doesn't fall while you are removing it.
Q. May the belay system be used to lift the ROBOT a small distance to aid in releasing it from the PYRAMID before lowering the ROBOT after the MATCH?
A. No. The belay system is meant as a safety against falling ROBOTS, not a removal tool.
So, I suggest designing a trigger that you can reach to release your robot, and your BELAY attachment points to be closer to the bottom of your robot
Peachtree Regional Volunteer since 2003
