Go to Post The entire season, when someone yelled "Robot" I would yell back "Human" and stand my ground. - DonRotolo [more]
Unread 15-01-2013, 14:15
Re: Relay/Spike Problems?
You're creating your Spike Subsystem in both of your commands. This is creating a relay object twice, both referencing the same hardware relay port. The second instance is throwing an exception. I suspect if you scroll up in the output window you will see a stack trace.
You should create a static instance of your subsystem in commandbase, and then reference the subsystem in your commands (without creating new objects).
