Re: Worm Drive
Andymark sells the Wormbox, which is a 16:1 reduction, and costs $120.
Re: Worm Drive
The wormbox is out of stock unfortunately. Otherwise I would be on board with that.
Re: Worm Drive
Look at SDP-SI. They sell all kinds of gears and pulleys. You should be able to find a worm gear and matching spur gear there that will fit your needs.
Re: Worm Drive
The gears, bearings, and shafts are in stock.
Re: Worm Drive
http://www.chiefdelphi.com/forums/showthread.php?t=80596&highlight=garage+door+worm
The above thread has a good link. I haven't used it but the gears look the same as the ones in the Andymark Wormbox. |
