Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Unread 15-01-2013, 14:28
yarudl yarudl is offline
FRC #0578
yarudl is an unknown quantity at this point
Worm Drive
Where is the best place to find a cost effective worm drive? I'm looking for something that costs about $200 or less preferably and has a 15:1 ratio. The input will most likely be 2 CIMs. Any thoughts? I've googled for a while and rino came up (now ondrives) but the boxes are still pretty pricey. Is the only option to cough it up? I know I could build one with gears from mcmaster or such places but I'd like to avoid that if possible.
Thanks,
Yarudl
Unread 15-01-2013, 14:35
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: Worm Drive
Andymark sells a worm gearbox, I think it is a bit of a higher reduction than what you want, but you could always speed it up in sprocket size.
Good enough is the enemy of anything great!
team 1671
Unread 15-01-2013, 14:37
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Worm Drive
Andymark sells the Wormbox, which is a 16:1 reduction, and costs $120.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-01-2013, 17:00
FRC #0578
Re: Worm Drive
The wormbox is out of stock unfortunately. Otherwise I would be on board with that.
Thanks,
Yarudl
Unread 15-01-2013, 17:21
FRC #1836 (MilkenKnights)
Re: Worm Drive
Look at SDP-SI. They sell all kinds of gears and pulleys. You should be able to find a worm gear and matching spur gear there that will fit your needs.
Unread 15-01-2013, 17:31
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Worm Drive
The gears, bearings, and shafts are in stock.
Unread 15-01-2013, 17:49
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Worm Drive
http://www.chiefdelphi.com/forums/showthread.php?t=80596&highlight=garage+door+worm
The above thread has a good link. I haven't used it but the gears look the same as the ones in the Andymark Wormbox.
