#16
Re: What does a defense robot NEED?
I'd hazard to predict that the best defensive bots will:
Weigh 120 pounds. Have two speed transmissions. Six or Eight wheel drive. Good Drivers. Four cim's on drive (six cims stalling will throw your main breaker, I think) Run every match. WON'T GET PENALTIES. Under 30 in tall (to fit under the pyramid) Their defensive strategy would either involve the choke points located between the pyramid and the wall (to slow down traffic), or camping under the opponent's pyramid and then running out to hit/ push them around when they try to score. You could also deny a climb this way. |
#17
Read Alec's post again. Please consider not building a defensive robot. The low rung on the pyramid and the 1pt goal are there to give teams of all skill levels the ability to play an offensive game.
#18
If your team has chosen to build a defensive robot, I suggest the following things:
1) Have a strong chassis. Use all 6 motors and have big, grippy wheels. The robot needs to be fast and strong to push other robots out of the way. 2) Be able to pick up frisbees from the defensive end and deliver them to your teammates to score. This strategy was perfected last year by "BombSquad" (Team#16) at FRC Championships. They were on the winning alliance, if I remember correctly, and used this exact strategy. Stealing the opponents' frisbees will both lower their score, and help raise your own score. 3) Be able to hang for 10 points at the end. It will help out your team and yourself. 4) Practice. If you want to be able to do well in competition,your drivers need to have a lot of practice picking up frisbees, maneuvering around obstacles, etc. |
#19
EDIT: This may not fall into the category of "need", but I would consider some of the following non-traditional forms of defense: 1. A very large fan to blow frisbees offline - people keep talking about it, but this year with the extra CIMs and aerodynamically sensitive game pieces, I really think it can work! 2. A robot that quickly picks up and shoots frisbees away (not off the field!) to deny the opposing team from picking them up 3. Keep them from getting into their loading zone - yes, their are rules from touching another robot in its loading zone, but there is no rule preventing you from going in their loading zone, as long as you keep them out! 4. Be as tall as possible to block frisbees - if there are any long shooters at your regional, have some way to get 84" high to block all their shots Last edited by bduddy : 15-01-2013 at 01:20. |
#20
Also, a defender that can 10 point hang is far more valuable than one that can't. |
#21
Defense is a strategy, rarely if ever a design. Designs can have features attractive to defensive strategies, but I wouldn't call any truly viable FRC design a "defensive design".
That said, the ideal robot to execute a defensive strategy - high traction drivetrain, shifting is nice but not required, excellent drivers. As you can see, this could be* most FRC robots. This is why everyone is advocating for you to build a simple offensive robot, such as a 1 point dumper or 10 point hanger. You can easily do both. Plus, offensive features lead to greater defensive strategies. Here's one example - let's say you add a floor pickup mechanism to a robot. You can start to play defense by picking up misses and other frisbees on the floor and then returning them to your side of the field. Last edited by Chris is me : 15-01-2013 at 02:12. |
#22
A good drive train with a good driver with solid knowledge of the rules and a coach who is an agile thinker who also has a solid knowledge of the rules is a good place to start.
#24
Be able to flip disks upside down this could be the biggest pain for a lot of teams. Most teams will make flipping devices but they take longer time flipping disks the right side up.
#25
Field trolling. I like!
#26
I've been in a lot of scouting meetings and made a lot of pick lists, I can't remember EVER considering to pick a robot with no offensive capability. At the very least we've decided on teams that might score in Auto and then we've instructed them to play defense ETC but we always base decisions on offensive contribution to our strategy. Obviously teams are well within their right to build a "defensive" robot. The reason I urge against it is because the team will struggle to make eliminations at their events without some offensives capability. |
#27
A great Defense robot will need to be able to do everything that the other two offensive robots on the alliance can't do, or can do them so they don't have to.
This includes but not limited to: 1: Hanging for 30 points 2: Handle and score 4 of the colored alliance discs in the pyramid goal. 3: Push around opponent's robots from their most effective scoring locations. 4: Push around other defending robots so your alliance's offense can go off without a hitch. 5: Travel fast around the field to bog down locations of high traffic for your opponents. 6: Maneuver around discs on the floor and under both pyramids easily and quickly. 7: Score in autonomous. 8: Have great drivers, coach, and communication skills with the rest of the alliance. 9: Have a great Feeder who can follow instructions and feed alliance robots correctly. |
#28
Are people forgetting that touching the opponents pyramid is a technical foul? If I were a drive coach I would have the robot steer clear of the pyramid, let alone have them drive under it to play aggressive defense on another robot.
Inconsequential contact will not be penalized - therefore I find it perfectly fine to utilize the space under the opponent's pyramid to drive around in for getaways or other fast travel. The real problem is avoiding robots that are touching their pyramid for sure.
#30
On a slightly related note, if I have a Q&A account, how do I submit a question, do I need permission from my team or something? |
