Go to Post IRI seeks to invite the very best robots to play the FIRST game, achieving the highest level of play, while keeping in place the FIRST atmosphere. - Nathan Streeter [more]
Unread 11-01-2013, 15:57
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Arduino as driver station joystick?
My team wants to be able to use an Arduino Uno board as a joystick with Labview, but i'm not sure if it's against the 2013 FRC rules because i can't find it in the rulebook.
Does anyone know if it's legal in the game or do I have to use a different joystick?
If it's legal, how do I get the Arduino to input as a joystick with buttons and axes into labview's joystick control?
Unread 11-01-2013, 16:10
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Re: Arduino as driver station joystick?
I know of no rules against it, but you might try the Q&A.
However, as far as I know, the uno is incapable of being a USB human interface device.
I have also heard there is a different arduino that IS meant to do that.
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Using an Arduino as a joystick is legal. But a better option may be the Cypress board that was included in the Kit of Parts, as it was provided to create a custom controller.
If you search on www.arduino.cc , you may find tutorials that input switches and pots and emulate a USB HID device just like the Logitec joysticks provided.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 11-01-2013, 16:22
Andy A. Andy A. is offline
Getting old
FRC #0095
Just to make sure I understand you correctly-
You'd like to use an arduino to mimic a joystick, such then it can generate perhaps programmed joystick moves?
Or were you planning on making your own joystick using the arduino as a method of collecting and processing sensor input (such as encoders) into a joystickesqe USB data stream?
Unread 11-01-2013, 16:23
ThaDeanesta ThaDeanesta is offline
AKA: Kyle
FRC #0175 (Buzz Robotics)
ThaDeanesta is an unknown quantity at this point
You might want to look into the Teensy 2.0 (OR 3.0) . It has hardware USB support, uses the Arduino IDE, and is very simple to use.
It is similar to the Arduino Leonardo, where the chip supports HID, but has many more libraries and easy-to-use features.
Teensy Joystick Examples
Teensy 2.0 - $16
It's definitely worth a look
Unread 11-01-2013, 18:24
WE just want Labview to read/initialize it as a joystick like the other USB stick we use, but this one just has maybe a couple toggle switches, a few buttons and status LED's for certain conditions.
If the uno is incapable of being a Human Interface Device, then can labview at least read the value of the pins to do the same thing?
We didn't get a Cypress board with our kit this year, we're veteran. Would the Cyress be easier to use with Labview if we bought that instead?
Thank you guys for all the quick responses!!
Unread 11-01-2013, 18:58
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I'm not familiar with how a HID would be implemented, but I've never seen it done before, as there are simpler alternatives - namely the Cypress and the CCI.
If you really need both I and O, then the Cypress would indeed be easier to use as a framework is already in place to implement it. If you only need I, however, then the CCI may be a simpler option. It's a product offered by eStop Robotics that emulates a USB Joystick and allows you to feed sensor input to the robot through the Driver Station.
If you've never done this before, I would suggest going with the CCI as it is a much simpler and robust product to work with. Think about how critical being able to send outputs to your operator interface is - how often is your operator going to look down at his control panel while he's behind that glass? Is he going to be able to interpret that data and actually use it in a match?
Alternatively, as previously mentioned, you can use the Teensy (4334 has a whitepaper here on CD about their implementation of it as a), which can emulate a USB Joystick. Alternatively, it can be implemented as a HID or serial device. Keep in mind that when a device is implemented as a Joystick, it is only capable of feeding input to your system - it cannot receive output.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 11-01-2013, 20:36
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
A word of caution about the Cypress boards. We used it last year and had horrible results. We went through two boards (both failed while in use) and learned from other teams at our regional that they have all abandoned the module because of its lack of reliability.
Here is a tip - buy a cheap joystick (used on ebay ~$10) and rip it open. You now have plenty of switches and pots for external control. If you need mor input, get a second joystick. You can use up to 4 if I remember correctly. We did that, worked like a charm.
Good Luck.
Unread 11-01-2013, 23:10
cdewane cdewane is offline
FRC #3381 (Droid Rage)
cdewane is an unknown quantity at this point
If you want to stick with the Arduino ecosystem, the new Leonardo board has the capability to act as a HID device. It costs $25 from Sparkfun.
http://arduino.cc/en/Main/ArduinoBoardLeonardo
https://www.sparkfun.com/products/11286
Unread 13-01-2013, 19:20
pribusin's Avatar
Uber Alien
AKA: Mike 1
@cdewane, do you know more about the Arduino/Leonardo HID? Availability of Libraries etc.? Thanks.
Unread 13-01-2013, 19:26
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Uhid can get button/analog data into a HID data structure. Looks like a HID (no drivers) to the Driver Station. Input only (when acting as a joystick). It's awesome.
I personally hated the Cypress board when we used it in 2010. We will NEVER use it again, we had far too many reliability issues with the drivers. The drivers then were very very unstable and would lockup after coming out of sleep, and we had to write code to workaround a lack of Cypress input and map key function to other places (on the driver's gamepad).
Kettering Motorsports
Unread 14-01-2013, 11:00
@pribusin While I have used various Arduino boards over the years, I don't yet have a Leonardo. The Leonardo just came out this summer with HID support out of the box. Keyboard/Mouse emulation is the easiest, but I did a quick Google search for "arduino leonardo hid joystick" and found that people have gotten joystick emulation working as well. It may take a little more effort but it seems possible. I am a huge fan of the Arduino platform, very affordable and easy to use.
Unread 15-01-2013, 15:51
If we got the Leonardo, is there something that would need to be implemented into it's code that would let it input into Labview just like any other USB joystick? or would it just do itself with the HID protocol.
Unread 15-01-2013, 16:01
pribusin's Avatar
Uber Alien
AKA: Mike 1
If it's a true HID implementation then it needs no drivers and LabView should recognize it as any normal joystick with its analog axes and digital buttons.
We're still looking for an alternative to the Cypress module for its output capability so that we can send outputs back to our control box on the driver station. A joystick, keyboard or mouse HID can't do that.
Unread 15-01-2013, 17:24
So is there any code that would need to go into it at all? Wouldn't there have to be some code running on it telling Labview how many buttons or axes there are on it?
