Go to Post As in life, the more restrictive the rules, the more creative the 'best' solution will be. - DonRotolo [more]
Unread 15-01-2013, 15:04
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
*Warning* On talons!!!!
Teams should be careful with talons because they load is only 100V and a Cim Motor is 120V i know this post is not that professional and i apologize for that i just wanted to warn teams.
-Team 3038
edit this is the correct amps thanks to Al Skierkiewicz
tomy,
correct that to 100 amps and 131 amps respectively.
Unread 15-01-2013, 15:06
Re: *Warning* On talons!!!!
tomy,
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I take it your talon is no longer working? Could you post a photo of the insides? Or if you haven't opened it up at least the outside?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 15-01-2013, 15:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
-Team 3038
You should have had a breaker inline to protect the talon from extended over-current.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2013, 15:10
We didnt blow a talon our lead mentor looked into a talon before hooking it up and sorry again for the wrong amp i will change it
Unread 15-01-2013, 15:25
I believe CTRE has tested the Talon and it is capable of handling just about anything the 40 amp breaker is capable of throwing at it, as long as the fan is attached. Mike C please correct me if I have misrepresented that.
Unread 15-01-2013, 15:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Unfortunately, there aren't numbers available for the Victor 888 (the website says "Update Coming Soon", last time I checked). But some specs to compare:
Jaguar:
Continuous current: 40A
2 second current: 60A
peak at startup: 100A
Source: http://content.vexrobotics.com/docs/..._Datasheet.pdf
Talon:
Up to 100 amps peak 60 amps continuous current.
Source: http://www.crosstheroadelectronics.c...Manual_1_2.pdf
The Talon really isn't any different from the other speed controllers, and you'll only risk blowing one if you design something poorly (like a CIM motor that's constantly stalled). We've used Jaguars for years on our drive train, and never blown one, I don't expect to see anything different from the Talon.
The breaker is present to protect the wiring, not the components attached to it.
2016: Lake Superior WFFA
Unread 15-01-2013, 15:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We ran a talon with fan in a drive train stalled and pulled a continuous 78 amps by using multiple 40amp breaker inputs with no problem for extended periods of time during our beta testing.
An FRC robot should have a 40 amp snap action breaker that should not allow the Talon or Any Other motor controller to see 100 amps continuously for any amount of time.
Can you please detail your robot setup to show us how you pulled 100 amps long enough to damage the Talon?
Jorge Ayala's Avatar
Jorge Ayala Jorge Ayala is offline
FRC #3478 (LamBot)
Jorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to behold
My team has been using Talons for a while, some months before the kickoff and so far any problems have been noticed. Actually, we did have some problems with Jaguars before using Talons.
Website
Facebook
Twitter
Victory goes beyond winning.
Unread 15-01-2013, 16:00
See my previous post.
Unread 15-01-2013, 16:04
The point of this thread was to get the knowledge out there to be careful
Unread 15-01-2013, 16:12
Yes, but the "knowledge" is incorrect, misleading and poorly communicated.
Please do not spread Fear/Uncertainty/Doubt without evidence.
Unread 15-01-2013, 16:21
Tom Line's Avatar
I am still very confused about what we should be careful of. Used correctly, none of the first motor controllers will ever see that amount of current long enough to damage them.
Unread 15-01-2013, 16:57
mikeleslie mikeleslie is offline
FRC #1189
mikeleslie will become famous soon enough
So what I'm reading is that according to the spec, you should be careful using a Talon on an unprotected circut, so don't connect directly to the battery on one side with a CIM locked in a vice on the other.
Just testing my underastanding of the issue...
Of course if you wired things up similar to what's shown in the rulebook, you would have 2 breakers, both of which should go long before the Talon.
Unread 15-01-2013, 17:00
Cory's Avatar
AKA: Cory McBride
I understand that, but as a result, the Talon should never be able to see 133A.
2001-2004: Team 100
