Go to Post Safe zones are for the weak. - ChristopherSD [more]
Unread 15-01-2013, 16:23
2509tigerbots 2509tigerbots is offline
FRC #2509
2509tigerbots is an unknown quantity at this point
Question Labview 2012 or 2013?
We are confused on whether to be using Labview 2012 or Labview 2013. Where do you get Labview 2013? When we installed the packet we got in the KoP, Labview 2012 installed, but we have seen people with Labview 2013. Also, there was no base code in the Labview 2012 that we got.
Thanks,
Tigerbots
Unread 15-01-2013, 16:26
Re: Labview 2012 or 2013?
The 2013 FRC Version of LabVIEW is LabVIEW 2012. It sounds like you did not install the LabVIEW update which installs the FRC specific components. http://wpilib.screenstepslive.com/s/...w-for-frc-2013
Unread 15-01-2013, 16:27
The "LabVIEW FRC 2013" package we use this year is built on LabVIEW 2012.
I think the "base code" you refer to is what gets installed when you run the LabVIEW update that you should have downloaded (along with the Utilities and Driver Station updates).
