Go to Post Things that get said on the field should stay on the field. - Bongle [more]
Unread 15-01-2013, 02:22
mikeleslie mikeleslie is offline
FRC #1189
mikeleslie will become famous soon enough
R32 and the use of Electrical solenoid actuators
R32
....Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)...
Didn't have a need last year, and can't seem to find any posts discussing it, so does this mean I can stop retrofitting FP motors into (older, like from the 1990's GM trucks) standard GM door lock actuators?, or other power door lock actuators for that matter
They seem to fit the criteria, less than an inch stroke, 10w (probably)? I'm sure a Delphi would have real details. Or am I just wishing here.
Unread 15-01-2013, 02:50
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: R32 and the use of Electrical solenoid actuators
Don't use the Fisher-Price motors in any application, since they're not legal in 2013. (There are several can motors from BaneBots and AndyMark that are legal, which superficially resemble the Fisher-Price motors.)
As for electric door lock actuators with motors in them, they don't fall under the solenoid rule, so their stroke and power rating are immaterial. (It's a solenoid actuator rule, not an electric linear actuator rule.)
Unread 15-01-2013, 08:38
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Originally Posted by Tristan Lall View Post
...a solenoid actuator rule, not an electric linear actuator rule...
What is the difference between these two things?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 15-01-2013, 17:07
FRC #1189
So basically if it has a field coil and doesn't rotate then it qualifies. Like a striker on a doorbell or a small starter solenoid? or am i missing something.
Unread 15-01-2013, 19:56
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Everybody, this is a solenoid.
A solenoid actuator uses one of these to move something (the "armature") through its center. Typically the armature is either magnetic or ferrous (so that it will react to the field created by the coil.
Here is a good cross-sectional image of one (in this case it is used as a valve actuator, not unlike the pneumatic solenoids we use).
Most of the solenoids here are similar to the ones the rule is referring to.
I hope this helps someone.
Unread 15-01-2013, 20:47
Solenoids that fit the rule can be found at McMaster Carr.
Unread 15-01-2013, 20:48
The door lock actuators described above are an electric motor hooked to a lead screw and/or reduction gears (like this). The solenoid actuators (like the ones Alan linked) don't have motors inside.
We've argued about this definition in the past. My impression is that a solenoid actuator necessarily implies a proper solenoid (i.e. an energized coil that produces a substantially uniform magnetic field in the space along the length of its internal axis, with a plunger that moves along that axis, through that space, as a result of the electrical current supplied to the coil); others have suggested that a less restrictive definition satisfies the rule. In my opinion, a conventional electric bell is not a solenoid actuator.
