Go to Post You can never have enough teamwork. - Koko Ed [more]
Unread 15-01-2013, 18:39
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Please help - launcher issues.
Hello everyone.
We've been prototyping our launcher since build season started, and we're not happy with where we are.
We've done a variety of things from changing wheels, changing gear ratios, speeds, changing compression, putting on a roof, changing angle, using double wheels, etc.... all to no avail.
We're getting meager distance out of these - 20 feet max. That may not be too bad, but the 20 feet max is only achieved if we fire the frisbee at a height of about 3 feet: in other words, not fast enough to get into a 3 pointer if aimed upward.
Here's a few images of the launcher.. hoping we can have some guidance. Thanks a ton.
https://www.dropbox.com/s/zj1reqr86y...2018.17.19.jpg
https://www.dropbox.com/s/qcgogzwmy6...2018.17.23.jpg
https://www.dropbox.com/s/7kpa1f6gk1...2018.17.36.jpg
https://www.dropbox.com/s/x58fce6j59...2018.17.43.jpg
Gear ratio on the front wheel is roughly 1:2.375
Gear ratio on the back wheel is roughly 1:2
Both being run at a bit over 12V via direct battery hookup.
We're just getting a bit frustrated because we've seen very very very simple prototypes work much much much better and have not been able to achieve a satisfactory result with hours upon end of adjustments and changes.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 15-01-2013, 19:30
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Please help - launcher issues.
Without seeing a video, it looks like you might be seeing a lot of slippage. A CIM(?) geared like that at that kind of voltage seems waaaay too fast, especially using a non-compressable wheel. Faster != better.
I would say start with what has worked for other teams so far. Pneumatic wheels, 1:1 ratio first wheel 1:1.25 ratio second wheel, 10-11 volt range on both. If that yields better results, start tweaking one variable at a time until you find something that works well for you.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 15-01-2013, 19:40
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
1.2 off what motor - I can't see them in the pics.
My best guess is you are getting a lot of slippage using those wheels. And those wheels are not very wide - very little room for alignment errors. Our mock-up is very close to yours but we are using an old 2" wide IFI high-traction wheel.
Try cleaning that wheel (scrub it hard, they get stickier when you do) and try other higher-traction wheels.
Good Luck!
Unread 15-01-2013, 20:07
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
From what is shown in the photo, I would guess that you are getting a LOT of slip between the wheels and the disc - those wheels are pretty firm, and you only have a single squeeze point for contact in a linear shooter. What other types of wheels have you tried?
Part of why the Ri3D shooter used pneumatic tires is because they can compress a lot and significantly increase the contact time for a linear shooter. As has been discovered by many now, those particular AndyMark pneumatic tires have weaknesses for high speed use, but the principle of a more forgiving tire and greater compression for a longer contact is sound.
Does anyone on the team have a camera with a high speed video mode so you can try and see what is happening? (many newer point and shoots have low res, high speed video modes)
I am not terribly familiar with the Modulox gearbox system, but based on the small gear I can see on the CIM, and the larger gear mated to it I think you have a gear reduction set up, is that correct? You can check by slowly turning the output wheel by hand and counting the revolutions of the motor shaft - if the motor spins more than once for one turn of the output, then you have a gear reduction.
Our team always likes to start prototyping shooters by directly connecting a CIM to a wheel, since it keeps things simple (too much squeeze can be rough on the motor bearings though). There has also been some talk online this year about teams wanting to gear up their CIM to make the wheel spin faster (as Ri3D did).
Some suggestions to test: higher grip wheels, more compliant wheels, greater squeeze/compression (to a point), and start with 1:1 off the CIM to keep things simple.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 15-01-2013, 20:14
ttldomination's Avatar
ttldomination ttldomination is online now
Sunny
http://www.chiefdelphi.com/forums/sh...70#post1216070
1648: 2013-2014
5283: 2015
Unread 15-01-2013, 20:19
teh_lol's Avatar
teh_lol teh_lol is offline
FRC #0486 (Panther Robotics)
Team Role: Driver
teh_lol is an unknown quantity at this point
It seems that using the FIRST wheels is problematic, since they do not compress. This would distort the frisbee slightly when going through the shooter. Next the linear design can also be imparting only a little of the momentum, since the frisbee will only be given momentum from the wheel at a single point.
Unread 15-01-2013, 20:24
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
This thread may help
http://www.chiefdelphi.com/forums/sh...hreadid=111336
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 15-01-2013, 20:41
ksafin's Avatar
AKA: Kirill Safin
Thanks for the feedback guys. To address a few questions:
We are indeed using CIM Motors.
We are not doing a reduction or 1:1, both gearboxes are geared up; 1:2.375 and 1:2.
We'll try 1:1 tomorrow and try to put on pneumatic tires. We have them, but it's been challenging to get the hub on them to stay straight and not have them wobble on the shaft.
Unread 15-01-2013, 20:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
You maybe spinning the wheel TO FAST. Causing slip between the wheel and the disk, which would decrease performance. Try adding a victor and running at slower speeds.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 15-01-2013, 21:06
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
This may or may not be your problem, but it was our problem.
Make sure you test with the official FIRST discs. We got a bunch of generic frisbees to test with ad we were really disappointed with the horrible distance (about 5 feet) that the discs were flying. Then I tried loading in one of the FIRST frisbees and those flew over 50 feet.
Most likely one of the previous posters already identified your problem, I just thought I'd post this here just in case it could be helpful to you or someone else.
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 15-01-2013, 21:55
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Use pneumatic wheels!!!!!
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 15-01-2013, 21:56
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Try different wheels, not necessarily pneumatic but try KOP wheels etc. Put more compression on the frisbee.
https://kusha.me
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Agreed, or go for something with more grip, like some plactions ( what our team is using for a prototype)
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 15-01-2013, 22:46
DonRotolo's Avatar
Back to humble
FRC #0832
Absolutely too fast. Try 1:1 and 80% speed (~10 V), at least on the first wheel.
Unread 16-01-2013, 07:48
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
slipping is a problem with those wheels we made a arc shooter with just a single wheel the wheel was directly connected to a CIM. when the frisbee went through it scuffed the frisbee and the wheel was shedding thin rubber strips. a wheel with better traction and a a wall that is slippery should work fine don't use a placation wheel as the tread around it will fly off and possibly hit someone like that almost happened to us
