Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 15-01-2013, 21:08
Re: A minor problem with our router
Do you have the instructions for setting things up? You're apparently doing things that aren't called for. Start here:
http://www.usfirst.org/roboticsprogr...ical-Resources
You'll need the 2013 FRC Bridge Configuration Utility, and you'll need to follow the Programming your radio for home use directions.
