Go to Post Because after Kickoff....ZOMBIE MODE, HERE WE COME! - Dorienne [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.82 average. Display Modes
Unread 15-01-2013, 21:22
Re: cRIO imaging tool hangs on "Rebooting cRIO"
We imaged a fresh cRIO this evening. It stuck at the "Rebooting cRIO" step. It took us a while, but we finally tracked down something that was misconfigured on our computer. Somehow the wired network interface had gotten two IP addresses set, and removing the extra one let everything work properly.
(I'm guessing the extra address ended up there when we selected the wrong interface in the D-Link configuration tool a half hour earlier, but I'm not about to go through that mess again to verify the cause of the problem.)
So I suggest that you double-check the "Advanced" IPV4 properties of your network connection and delete any superfluous entries.
