Go to Post probably another ingenious game hint planted by Dave months before anyone even thinks about a game hint! - skimoose [more]
Unread 15-01-2013, 09:59
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: 3rd level climb even possible?
Originally Posted by F22Rapture View Post
How would you implement a pneumatic climber? I could definitely see using pneumatics to actuate claws, but aren't they mostly useful for pushing and not pulling, as the majority of the movement in the climb would be?
They can be used to drive linkages that lift the entire robot.
This really isn't that tough to design, the biggest issue is the weight of the cylinders and the volume of air needed to drive the system, However I haven't put too much thought into it yet but I'm sure it can be done.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 15-01-2013, 11:44
pfreivald's Avatar
AKA: Patrick Freivald
My math on the air charge needed makes a linear pneumatic system untenable. Combined with other mechanisms it becomes much more viable.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 15-01-2013, 14:30
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Is the 30 point climb worth the effort. I think we will see teams do the 30 point climb on the first weekend of the regionals. I also think we will see teams fall from 3 to 5 feet and distroy their robot for the weekend. It is easy to do a 10 point climb with the only problem to worry about is a robot falling on you from above. I think the climb is not the game changer, the changer is getting the 6 disc in the top of the pyramid (30 points). I do not think that the 30 point climb is worth the effort if it DOES NOT takes away from your shooting abilities.
Unread 15-01-2013, 22:51
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Looking back at 2010, battery power really isn't a problem.
Unread 15-01-2013, 22:55
pfreivald's Avatar
Are you sure? Two feet isn't six.
Team 1551
I write books, too!
Unread 15-01-2013, 23:03
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Not only battery power but I'm especially worried about teams who plan to use pneumatic power. There are only so many tanks you can strap onto your robot.
Unread 15-01-2013, 23:23
pfreivald's Avatar
Unassisted pneumatics are not a viable solution, to be sure.
Team 1551
I write books, too!
Unread 15-01-2013, 23:29
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Run out of battery power? No way.
Let's do some math:
150 lbs ~= 70 kg
Assume you want to raise your robot 2 meters (78 inches)
PE = m*g*h = 70 kg * 9.8 m/s^2 * 2 = 1400 Joules
The battery has an 18 Amp-hour capacity (although you don't this much out of it in practice).
18 Ah * 12 V = 18 * 12 * 3600 Volts*Amps*seconds = 78 kJ
So climbing would use just under 2% of your battery power.
Or, looked at another way, let's assume your robot has a maximum speed of 4 meters per second (13 feet/second). To accelerate to top speed requires
KE = 1/2 * m * v^2 = 1/2 * 70 kg * (4 m/s) ^ 2 = 560 Joules
So, if we pretend that all our mechanisms are frictionless and 100% efficient, sprinting from one side of the field to the other three times is very roughly equivalent to climbing the tower.
No. In fact, I've heard it argued that you should always use pneumatics to pull, rather than push, because that way you don't put the rod into compression and risk bending it.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 15-01-2013, 23:37
pfreivald's Avatar
After an entire match of compressor running, pushing/shoving, shooting, etc, etc?
Entirely possible to not have the oomph necessary to do what was designed to be done at "12V"*, especially if the design doesn't compensate for the drop in available voltage after ~90 seconds or so of a match.
*Likely more, as 12V batteries aren't, well, 12V.
Team 1551
I write books, too!
Unread 15-01-2013, 23:44
AKA: Steven Bell
Yes, it's possible to kill your battery, and designing your climbing system for a fresh battery is unwise. But it's pretty rare that robots can't still drive across the field by the end of the match. Power-wise, climbing isn't actually any worse than driving around.
Unread 15-01-2013, 23:46
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yep. We're climbing to the third with only two FP motors right now (I think they're illegal, but its just for the prototype as of now)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 16-01-2013, 11:40
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
It is very possible, but also very hard. That's why its worth 30 points, so that teams will actually attempt it.
Unread 16-01-2013, 14:44
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Steven,
Keeping the rod in tension rather than compression is a good idea, but you should actually do the bending calculations before ruling out pushing with a cylinder. Most cylindars are designed so that their rods can handle max force the cylindar can produce in compression. Rods are typically destroyed by side loads.
Also cylinders usually have more push force than pull force due to the area taken up by the rod.
___________________
- Tennyson, Ulysses
