Go to Post Paul: "IDK, my BFF Karthik?" - jgannon [more]
Unread 09-01-2013, 00:00
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
unlimited storage tanks and cylinders??
Can someone verify that I am correct that I am not reading any pneumatic rules that prohibit the number of storage tanks or the number of cylinders and stroke length et cetera other than limits based upon BOM and COTS price limits?
Having been at this since 2001, I recall strict limits in the distant past of max four storage tanks and four or five cylinders with stroke length limits of 24 inches.
I've read the pneumatic rules section of the robot rules as well as the 2013 FRC pneumatic handbook. I'm just not seeing restrictions/limits so please point them out to me with a reference page or the like if you see them.
thanks,
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 09-01-2013, 00:29
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Re: unlimited storage tanks and cylinders??
As far as I remember, that is basically how it was last year, whatever tanks you want as long as you are under weight. Haven't actually read that section of the rules too closely yet, but it sounds like it hasn't changed.
Unread 09-01-2013, 01:19
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
There have been no limits since 2011, before then we were limited to 2" bore and 24" stroke for cylinders and could only use a limited number of tanks identical to those supplied in the KOP
Unread 09-01-2013, 08:12
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Consider that the tanks were supposed to be filled by the competition battery each match, and that tanks do not fill instantaneously (some teams took 7+ minutes to fill). This may not seem like a big deal, but it's definitely something to panic about when you've just let the air out and you have 5 minutes to be on the field.
GitHub
Unread 16-01-2013, 00:24
Slartibartfest Slartibartfest is offline
FRC #1758
Slartibartfest is an unknown quantity at this point
How many uses can you get out of a piston? Is there a calculation one can use to figure out how much air pressure/ volume the robot would need to actuate the piston X number of times?
Unread 16-01-2013, 00:33
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
clandry94 is an unknown quantity at this point
Can you cite this rule about using the competition battery to fill tanks? Interesting.
Unread 16-01-2013, 00:53
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
I'm not sure that there is a rule about this. Last year we would fill ours in the the pit pre-match to ensure we had enough to deploy our appendage (see http://youtu.be/g_7ljqbIdi8 if you don't know what I'm talking about) at the beginning of the match
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 16-01-2013, 00:58
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
R80
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate. Off-board compressors must be controlled and powered by the ROBOT.
The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT prior to bringing the ROBOT onto the FIELD.
They obviously wouldn't notice if you charged your tanks with a big compressor in your pit prior to leaving to the field, and I'm sure some teams probably do it that way anyway, but there's the rule regardless. I'm actually glad this was brought up, I wasn't aware of this rule either.
Unread 16-01-2013, 01:11
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
There was a big issue last year at one of the regionals where a team was using a shop compressor in the pits to recharge their tanks in between elimination rounds. This potentially allowed them to recharge their tanks faster than otherwise would have been possible for teams following rule R80.
This caused a bit of an uproar here on CD, which makes me believe regionals will be looking more closely at teams with such compressors in their pits this year to make sure they are following the rules.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-01-2013, 04:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
In the even-more-distant-past, the 2000 KOP contained a 1.5 galU.S. air tank, and the 1999 KOP had some sort of long, thin air reservoir. But you're right: for several years, only 4 or fewer Clippard AVT-32-16s were allowed.
This year, there are no air volume limits (other than presumably the robot volume limits...).
I still hate this rule. It's trivial to exploit (legally, via spare1 batteries, compressors, tanks and fittings), and adds negative value to the system (same inherent safety hazards, but with more points of failure exposed by repeated connections and disconnections).
FIRST should allow teams to draw pre-charge air from any appropriately regulated device connected to the robot's on-board high-pressure pneumatic circuit (mandated to contain an overpressure relief valve and be constructed of appropriately rated components). But they don't.
1 Spares aren't defined this year. But presumably they're allowed, and not subject to the module rule. Because if not, all hell breaks loose.
Unread 16-01-2013, 09:16
To clarify,
The restrictions were removed by the GDC in 2012 to allow teams more leeway in their pneumatic designs. The restricting factor is the 1/8" fittings and 0.32cV rules. Inspected for these devices, there should be no serious issues. Large cylinders cannot be moved with any sufficient speed due to the restrictions in volume/air flow.
The pneumatic rules are written such that a single KOP (or equivalent) 1.05 CFM compressor can be used either on board or off board the robot to pressurize storage on the robot. This compressor (either on board or off board) can only be powered by the robot battery under control of the robot Crio and under software control to automatically shut off when the pressure switch is satisfied.
If officials suspect that a robot has been pre-charged with the use of a compressor other than as described above, they can release it's pressure. There are several other remedies in place up to and including disabling, yellow card and red card. Think that a team that uses a method other than that described above is actually taking the field with a robot that has not passed inspection. Check the rules regarding fielding a non-inspected robot for further details.
Unread 16-01-2013, 09:29
pfreivald's Avatar
AKA: Patrick Freivald
To clarify,
Is it the intent that the robot be charged, and then the battery swapped for a "fresh" one before going to the field?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 16-01-2013, 09:30
Pat,
There is no intent stated or implied.
Unread 16-01-2013, 09:31
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Consider that the tanks were supposed to be filled by the competition battery each match, ...snip
The rules require the compressor be powered & controlled by the robot. Rule very clear & specific. Nothing in the rules require the air storage tank to be discharged between matches or the battery used to recharge the tank be the same that is used in the match.
Al sort beat me to this.
Unread 16-01-2013, 09:57
pfreivald's Avatar
Pat,
Fair enough. What I mean is:
"Last year, we were charging our robot's air tanks, then swapping the battery before we went out on the field. It never occurred to me that this might not be entirely within the intent of the rules, and I guess I just assumed that all other teams were doing this as well."
I believe at this time that we interpreted the rule correctly and are in compliance with common and game-legal practice.
Sound about right?
Team 1551
I write books, too!
