Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 16-01-2013, 00:58
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: unlimited storage tanks and cylinders??
Originally Posted by clandry94 View Post
Can you cite this rule about using the competition battery to fill tanks? Interesting.
R80
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate. Off-board compressors must be controlled and powered by the ROBOT.
The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT prior to bringing the ROBOT onto the FIELD.
They obviously wouldn't notice if you charged your tanks with a big compressor in your pit prior to leaving to the field, and I'm sure some teams probably do it that way anyway, but there's the rule regardless. I'm actually glad this was brought up, I wasn't aware of this rule either.
Unread 16-01-2013, 01:11
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
There was a big issue last year at one of the regionals where a team was using a shop compressor in the pits to recharge their tanks in between elimination rounds. This potentially allowed them to recharge their tanks faster than otherwise would have been possible for teams following rule R80.
This caused a bit of an uproar here on CD, which makes me believe regionals will be looking more closely at teams with such compressors in their pits this year to make sure they are following the rules.
Art Dutra IV
世上无难事,只怕有心人.
