Go to Post I have caught a very strong case of FIRST fever. - weinbergmath [more]
Unread 16-01-2013, 10:26
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
tapping CIM axles?
for direct drive. good idea or bad? why? any ideas on how best to accomplish? thanks!
Unread 16-01-2013, 10:30
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: tapping CIM axles?
What does this accomplish exactly that a keyed shaft and hub or coupling can not?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 16-01-2013, 10:35
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
if you don't have those things, tapping the shaft works well. We have used all three methods in the past.
Unread 16-01-2013, 10:42
I wonder if this would work:
Put the CIM in the freezer for 10 minutes, drill a hole in the piece you want to connect the CIM shaft to, heat that piece nice and hot, and shrink fit it over the CIM shaft.
Unread 16-01-2013, 11:00
mrnoble's Avatar
teacher/coach
We're using keyed hubs mounted to skateboard wheels, and would like the wheels to stay on the axle, so are tapping it to place a washer over the top. Just did one and it worked very well. Thanks!
Unread 16-01-2013, 11:05
wilsonmw04's Avatar
Coach
Hmmm, Interesting idea. I might have to try that sometime.
Unread 16-01-2013, 11:45
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
It's potentially easier to heat up the part you're installing on the CIM with a torch. Raising the temperature by 300-600 degrees with heat will get a bigger dimensional change than cooling by 100 deg.
When this sort of thing is done IRL (bearing races, for example) one part is usually put in an oven and heated to 300-500F and the other part is put in an alcohol bath with dry ice at -109F.
As for actually retaining something on a CIM shaft, check out the normal pinion retainer rings available from AndyMark and/or VEXPro. They may seem a little flimsy, but do a pretty great job holding on.
Unread 16-01-2013, 11:57
did you miss this part?
Unread 16-01-2013, 12:02
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Yes, yes I did, clearly.
Unread 16-01-2013, 14:14
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
it works just fine my team did it while prototyping. it took a while but it works just be sure not to tighten the screw to much as it can rub and not work as well but keep it tight enough so the wheel doesnt wobble or it will vibrate to much and well in prototyping lets just say i hurt my finger
Unread 16-01-2013, 15:51
Originally Posted by thedude019 View Post
it works just fine
Please, what does the pronoun "it" refer to?
Your post is linked to this one:
http://www.chiefdelphi.com/forums/sh...39&postcount=9
Unread 16-01-2013, 16:39
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Silly question, but is it legal to do this? I know FIRST has very specific rules on modifying motors.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 16-01-2013, 16:59
mrnoble's Avatar
teacher/coach
Yes, I think it is legal to tap the axle to mount a screw. It does not change the performance or safety of the motor, which are FIRST's concerns.
Unread 16-01-2013, 17:04
R33
The integral mechanical and electrical system of any motor may not be modified. Motors, servos, and electric solenoids used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
However, the bearings on a CIM don't like side loads at all. They are only bronze sleeve bearings.
Also, are you drilling and tapping across the shaft or down the center of the shaft?
Unread 16-01-2013, 17:30
mrnoble's Avatar
teacher/coach
Down the center.
