Go to Post (Funding will be plentiful...) Where is this magical land? We can move our team there! - Tungrus [more]
Unread 16-01-2013, 12:39
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Prototype Small Wheeled Shooter
Originally Posted by dodar View Post
You sir, have just lightened up alot of robots.
We hope so.
Try slowing that second motor down (the BAG motor) . Try running it at ~10 volts.
See what happens. Easy enough to do.
Thanks for the recommendation; we still have a lot of work to do to optimize the whole setup. With the versplanetaries we can swap around motors and gear combinations so quickly that we plan to test a large number of them. We're also going to try to standardize on voltage as well, but that will take a bit more programming (since we don't have any type of speed feedback we can't do Bang Bang yet). We'll take your advice and test it. We agree that the last wheel is spinning too fast and is most likely slipping.
Originally Posted by ParkerF View Post
Allen,
This is great work! I admire your lack of hesitation to give away this information. Shows you and your team's true colors.
Thanks and good luck at making it even better!
-Parker
P.S. - Have you tried shooting from the floor? What kind of angle do you expect to have to pitch the shooter to for the 3pter?
Thanks for the compliments. That really depends on how high we end up shooting from and our distance away from the goal. I'm not sure we could give a number. That height was less than 5 feet so in theory we could just shoot from there.
Originally Posted by Robo Hamsters View Post
Just wondering how you set the one gearbox to be a 1:1 ratio?
Also, anyone have any ideas as to how you mount the banebots wheels directly to a CIM?
Thanks
We took the ring gear, sun, and planets out of a 10:1 versaplanetary. I'm not sure if you can do the same with the other gearboxes. Paul Copioli can probably expand on that. If I remember I'll post pictures in tonight's blog update. We'll probably have to swap around a few of the gear ratios during testing anyway.
Also we were wondering how you direct drive the banebots wheels with a CIM.
My thought would be to get an AM 8mm Hub and drill out the Banebots wheels for that and bolt them to it. I think it would work better than the 8mm to 1/2 hex adapter (It's not very long).
Originally Posted by Tom Line View Post
Locking a stage in a planetary gear is fairly simple - look up how people did it with globe motors. It involves glueing the sun gear and planetaries together with something, then dremeling off the teeth of the planetaries so they don't touch the ring gear.
It's much easier than that. The spline on the output shaft is the same as the one on the sun gear. You just remove the whole 10:1 stage and bolt the front and back of the gearbox together.
Unread 16-01-2013, 12:41
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Originally Posted by AllenGregoryIV View Post
We just posted a blog entry about our current prototype shooter. It uses much smaller diameter wheels than many teams that we have seen post of CD. We're hoping this idea might inspire some teams that are struggling to package their large shooters.
Blog Entry with full specs on the shooter configuration.
Youtube Video
Will all three wheels fit on the versaPlanetary Gear Box output shaft?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2013, 12:45
Engineering Coach
The three 0.4" wheels fit perfectly. The two .8" wheels have about .5" sticking over the top of the shaft, we just put a longer 1/4-20 bolt on with a washer, seems to work well enough.
Unread 16-01-2013, 12:48
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
Why did you go with 2 different wheel thickness? Just what you had around?
2012-2016 Wave Robotics Team 2826
Unread 16-01-2013, 12:53
Engineering Coach
The .4" orange wheels can be bought using the BB PDV. We purchased 2 .8" of all three colors after we tested how grippy they were to the discs. We just left the .4" ones on there for now. We'll best testing a bunch of different wheel combinations over the next week.
Unread 16-01-2013, 12:58
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Great work guys. Can you tell us the distance away from the goal you were shooting into in the video?
"A genius is just a talented person who does his homework" T. Edison
Unread 16-01-2013, 13:19
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by IndySam View Post
Wow. I'd never noticed that before.
Unread 16-01-2013, 13:34
Engineering Coach
The front of the board was at about 15 ft.
Unread 16-01-2013, 13:53
We're also going to try to standardize on voltage as well...
If you want to do speed control, your voltage at the desired shooting speed has to be a bit less than the lowest voltage you expect to see from your battery while you're shooting -- in order to allow headroom for you control algorithm to work.
Unread 16-01-2013, 14:38
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Did you or are you going to try the larger diameter (3.875" or 4.875") Banebot wheels?
Unread 16-01-2013, 14:46
Engineering Coach
We didn't and we aren't planning too. We don't have any, and we like the small form factor. We did have a 4in RC Buggy wheel you can see in previous prototype videos on the blog that worked very well but it was too big for us.
Unread 16-01-2013, 15:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Better question is whether there's anything to be gained adding a third wheel to the setup so you can make a smother transition up to the final wheel speed. Something like starting with the BB550 in a 10:1 then BB550 in a 5:1, then the 1:1 BAG. I'm pretty sure the higher initial velocity your final wheel sees, the farther you'll shoot and faster you'll recover.
Unread 16-01-2013, 16:12
1:1 BAG at free speed* is 14,000 rpm. With 2 7/8 dia wheel that's 120 mph tangential speed. With no slippage that's 60 mph.
If the frisbee is not exiting that second wheel at 60 mph it might be because it is slipping.
So, either:
1) crank down the speed of that second wheel a bit to stop the slipping and get a higher exit speed, or
2) crank up the speed of the first wheel, which is presently only 1930 rpm, which translates to 16 mph tangential velocity or 8 mph exit speed. A higher exit speed from the first wheel means a higher entry speed into the second wheel, which may reduce the slipping in the second wheel and give a higher exit speed
* I realize that due to windage and vibration it will be less than that
Unread 16-01-2013, 19:11
Engineering Coach
So, either:
Tonight's test has two BAG motors 3:1 and 1:1 (instead of a 550 and a BAG motor) and we're getting 30-35 feet from 2 feet off the ground and 0 degrees of incline. We also moved the blue wheels on the front and it seems slightly better. We're hoping that the harder wheels won't be eaten as fast as the green soft wheels.
Unread 16-01-2013, 20:19
Nice. Can you gear that 2nd BAG speed down from 1:1 to 1.2:1 and try again ?
