Go to Post What if my teams drive train isn't an option? - MARS_James [more]
Unread 16-01-2013, 13:06
ROBOGIRL2781 ROBOGIRL2781 is offline
FRC #2781
ROBOGIRL2781 is an unknown quantity at this point
Climbing Question
When climbing do you have to just touch the levels or do you have to hook onto and pull yourself up before going to the next one?
Unread 16-01-2013, 13:10
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Climbing Question
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID and/or the floor (Level 0) in
  • sequential order (Level 0, 1, 2, 3) during ascent and
  • no more than two (2) Levels simultaneously.
If a CLIMB is considered unacceptable (e.g. a ROBOT has touched non-adjacent Levels or more than two (2) Levels at a time), a Referee will indicate a rejected CLIMB by turning the offending ROBOT’S PLAYER STATION LED strings yellow. The ROBOT will be ineligible for CLIMB points unless and until it begins a new CLIMB from the floor, Level 0.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 16-01-2013, 13:17
FRC #2781
so do we actually have to hook on the first bar and pull ourselves up and then hook on the second bar pull ourselves up or can we just hook onto the second bar and pull ourselves so long as we just tap the 1st bar?????
Unread 16-01-2013, 13:20
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
You'd have to pull yourself up to the first bar. If you went from the ground (Level 0) to the second level, you would be in contact with two non-adjacent levels, not in sequential order. Thus. you have to go from ground to Level 1, Level 1 to Level 2, and Level 2 to Level 3.
Academic Student (Forever)
Unread 16-01-2013, 13:56
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
The robot just needs to contact each level (that you want credit for). There is no requirement to hook. So, if you can get your robot up to zone two while just tapping/touching/nudging/kissing/bumping the pyramid somewhere in zone one, that's a valid climb. Of course, subject to other rules, such as don't contact in 3 zones at once, don't contact in non-adjacent zones, etc.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 16-01-2013, 14:00
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
This is only true if you are NOT touching the ground (level 0) when you start
___________________
- Tennyson, Ulysses
Unread 16-01-2013, 14:09
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
As specified in Team Update #1, for purposes of climbing, the floor counts as a level of the pyramid (Level 0).
A.sequential order (Level 0, 1, 2, 3) during ascent and
B.no more than two (2) Levels simultaneously.
Therefore, even if you contacted Level 1 first, contacting Level 2 while you're still in contact with the floor would invalidate your climb.
Unread 16-01-2013, 14:13
AKA: Gerry
That's covered by the "subject to other rules, such as don't contact in 3 zones at once" part of my post.
So, for example, another robot on your alliance could lift your robot off the floor. Then your robot taps the pyramid somewhere in Level 1, then hooks onto the second rung. 10 points right there, 20 if the robot can lift itself all the way into Level 2.
Cal
Fairport, NY, USA
Unread 16-01-2013, 14:21
Mad Scientist
AKA: Me
FRC #2040 (DERT)
This would fail the sequential portion of the rules as you nees to go from level 0 thru 3. (If you are on another robot you are not contacting level 0)
___________________
- Tennyson, Ulysses
Unread 16-01-2013, 14:38
Jake177's Avatar
As I understand the rules, to make a legal climb, two things need to happen before you contact the Pyramid in Level 2. (Not necessarily in the order listed.)
1. You must contact the Pyramid in Level 1.
2. You must lose contact with the floor (Level 0).
If, for example, you only have a 10-point hanger, I don't believe there is anything in the rules precluding you from climbing entirely on top of a 30" partner (2), putting your bumper against the Level 1 horizontal bar (1), and deploying your hanger on the Level 2 horizontal bar.
Unread 16-01-2013, 14:52
pfreivald's Avatar
AKA: Patrick Freivald
That's my take on it, too.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 17-01-2013, 11:56
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Considering you must start fully supported by the floor, you certainly were touching Level 0 at some point... You might wish to read the CLIMB Points Q&A; we've been working pretty hard at clarifying this. While you may touch up to two levels simultaneously, there's no requirement to do so as you ascend sequentially.
