Go to Post Step 1. Understand the game and how to win the match and the event. - Chris Fultz [more]
Unread 16-02-2012, 05:23
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
How many rules does this catapult design break? :)
Prototype @ 35' : http://simhardware.org//img/FirstTry.avi
Slow Motion Study:http://simhardware.org//img/Compound...-2_slow-mo.MP4
Unread 16-02-2012, 07:40
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: How many rules does this catapult design break? :)
Hard to answer the question without seeing how it's mounted on the robot, but as a device, it looks effective and legal.
Unread 16-02-2012, 08:31
Dad,
Is that part of a compound bow with camo that I see? If so, I would want to know how you modified it for this mechanism. I can't tell much from the picture but my first response is usually one of safety and the possibility of this mechanism self destructing in firing. Is the material a laminate and is it capable of a dry fire without damage? I might have a UL safety person check this out during inspection if I was your inspector.
Unread 16-02-2012, 08:45
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by DavisDad View Post
The only issue I see with this design is safety during transport onto the field with the robot powered. You'd need either no energy stored in the catapult arm or a safety lockout (pin?).
Other than that, its a wonderful out-of-the-box type launcher.
Are y'all going to be at GSR?
___________________
- Tennyson, Ulysses
Unread 16-02-2012, 08:58
DavisDad's Avatar
MechE
Roger that on the safety. I've copied the Mathews mount ("limb pocket"), prestress and string angles as closely as possible. The cylinder (this one is temporary, final will be 1-1/2 bore, 6" stroke) adds a load to string to string during a dry-fire. I think the most likely failure mode would be pieces flying of the pivot arm.
Thank you all for the feedback. This may be a secondary launcher to our already developed spinning wheel shooter. If weight allows.
Unread 16-02-2012, 09:02
Glad to hear you are thinking about that usage in the design.
Unread 17-02-2012, 09:13
Dad,
I did a search and it appears that the parts you are using required no machining on your part, is that correct? More or less just a bolt on?
Unread 17-02-2012, 11:26
DavisDad's Avatar
MechE
Dad,
Hi Al,
Thanks so much for the thoughtful response. As a newbie mentor, your help is greatly appreciated.
The only parts that I made, that touch the composite bow limbs, are the "limb pockets" parts:
  1. Delrin guide/spacer for adjustible tension
  2. Ball socket (1/2 sphere washer) for bolt pivot point
If the shooter works well I may order OEM parts to eliminate doubt about the limb restraints.
I have been scrambling to get developed enough to test accuracy. If the performance pans out, I intend to make shop drawings and write up my analysis for review. Sorry I don't have this ready now...
Unread 17-02-2012, 14:10
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
how about
[R14]
No individual item shall have a value that exceeds $400.00. The total cost of Components purchased in bulk may exceed $400.00 USD as long as the cost of an individual Component does not exceed $400.00.
last time I checked the bow this came from cost around $900...
cole?
Unread 17-02-2012, 14:43
teh_lol's Avatar
teh_lol teh_lol is offline
FRC #0486 (Panther Robotics)
Team Role: Driver
teh_lol is an unknown quantity at this point
Originally Posted by 372 lives on View Post
how about
[R14]
You can buy just the limbs for a bow depending on the company that makes it and the piece that is taken.
Unread 17-02-2012, 15:27
DavisDad's Avatar
MechE
how about
[R14]
No individual item shall have a value that exceeds $400.00...
...last time I checked the bow this came from cost around $900...
I paid $40 at Reedy's Archery shop (Middleboro, MA) for a used set. The guy gave me a discount when I told him about our robot competition. He said he could get $80 used. I assume they cost about 2x that. I couldn't find a price on-line for the limbs new.
Unread 22-02-2012, 05:48
DavisDad's Avatar
MechE
My son and I tested the latest version of the “compound catapult” yesterday; properly sized cylinder and trigger release (couldn’t exhaust air fast enough}. We hit 6/6 @ 27.5’ (video below) until part failure. We were setting range by adjusting pressure until bow limb deflection was the same as measured by a caliper. We were cocking to about 75% of max force. We are working on the load beam/pressure transducer feedback cocking mechanism…
http://simhardware.org//img/Compound...atics30fps.MP4
http://simhardware.org//img/Compound...tics240fps.MP4
Unread 14-01-2013, 04:26
kclark kclark is offline
kclark is an unknown quantity at this point
I'm planning on making a smaller one of these for a project for college, where did you get the air cylinder from?
Unread 14-01-2013, 18:35
DavisDad's Avatar
MechE
http://www.bimba.com
You can buy direct from the "Buy Online" page.
Have fun!
Unread 16-01-2013, 14:07
do you know the part number you used?
