Go to Post "I would love to change the world but no one will give me the source code" - programmr [more]
Unread 16-01-2013, 15:51
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
Re: Team Update 1-15-2013
Originally Posted by CalTran View Post
Can we have a few more dimensions?
I meant his robot dimensions. It seems awfully small to keep his arm inside the frame perimeter for starting.
You are right it is a pretty small bot the frame is in the 20" x 23" neighborhood. Tight fit for all of the electronics but doable. The arms would have to be extended up right to fit inside the frame perimeter/starting config, but would be shorter than 60"
The purpose of this forum is to clarify Rules. We will not use it to declare strategies or designs unequivocally legal as there are factors in play beyond this forum. The 54 in. cylinder is not fixed to a specific reference point on the ROBOT when the ROBOT is contacting the PYRAMID. In other words, if a 54 in. right cylinder with a height of 84 in. could, in at least one orientation, fit around the ROBOT, the ROBOT is in compliance with [G23-1]-A.
Thank you GDC. I don't have to pull my hair out now. I only had to give away about half of the trade secrets.
