Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 16-01-2013, 17:32
Delta Delta is offline
FRC #3537
Delta is an unknown quantity at this point
Rule Clarification Help
We are wondering if we can get a little rules "help". Do you think it's okay if a fixed part of your robot "hangs over" the frame. as long a a) it stays with in the 54 in cylinder and b) doesn't extend beyond the bumpers. It is fixed (non-articulating).
Unread 16-01-2013, 17:40
cloudroth6 cloudroth6 is offline
FRC #4283
cloudroth6 is an unknown quantity at this point
Re: Rule Clarification Help
yes as long as it stay with the dimensions in the beginning of the round.
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by 2013 rules
R04
In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
If it's not a bolt head/fastener end/rivet you probably will have an issue during inspection.
___________________
- Tennyson, Ulysses
Unread 16-01-2013, 18:01
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Everything has to start behind the frame perimeter at the start of the match (with the rule exception of minor protrusions). No "mushroom bots"
Unread 16-01-2013, 18:52
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
Originally Posted by Daniel_LaFleur View Post
If it's not a bolt head/fastener end/rivet you will have an issue during inspection.
It will not pass..........
Starting configuration must be within your frame perimeter.
You can expand as soon as auto starts and stay that way as long as you are within the other size limitations.... height (depending on where you are on the field) and the dreaded 54" cylinder....
Remember also that anything hanging out is fair game for another robot to come along and hit with their robot and you may also have entanglement issues depending on how it is made.
Unread 17-01-2013, 09:04
FRC #3537
Smile Re: Rule Clarification Help
Thank you so much. I was pretty sure that was the case but...
We will just have to make some minor readjustments!
