Re: disk hopper ideas
Our team had similar concerns about using a magazine style feeder, that the frisbees would overlap and not enter the shooting chamber cleanly, so we decided to use a sliding feed mechanism, similar to what Robot in Three Days used. We haven't prototyped it yet but it seems like it should work.
We're planning on using part of a 5 gallon bucket as our magazine feeder, it works as a funnel to help orient the frisbees so they should be stacked cleanly at the bottom of the magazine
We too, were prototyping with the top of a 5 gallon bucket, it is the perfect size and its light. probably will end up on the robot.
You know it's the little things like "The disks fit perfectly inside a 5 gallon bucket." that make life so much easier. Although my team is opposed to it I want a 5 gallon bucket feeder; THE DISKS DO NOT OVERLAP. At least not enough to worry about, they way they curve the edges go out and back in preventing one from falling all the way on top of the other so you con stack them one on top of the other and push the one on the bottom out without affecting the others too much. Here is a good example http://www.youtube.com/watch?NR=1&v=JziVZvfsA3c.
We got our prototype working. But it is designed to use pneumatics...because we want to use them for another robot feature, and they're easy once you get the compressor running and the plumbing for the pressure regulator figured out.
http://www.youtube.com/watch?v=WddNQfBA5Cw |
What advantages do a five-gallon bucket give that three aluminum posts don't give at less weight?
#7
HOWEVER, I do not necessarily believe that the advantage will be terrible great. With a properly tuned system, I expect the differences to be greatly marginalized. - Sunny G. |
