Go to Post You are not limited by your resources, but by your imagination. - John Gutmann [more]
Unread 15-01-2013, 01:19
zsnow's Avatar
zsnow zsnow is offline
Head of Satire
AKA: Zachary Snow
FRC #2122 (Team Tators)
zsnow has a spectacular aura aboutzsnow has a spectacular aura about
Bug in WPILib
After scratching my head for a while dealing with peculiar behavior, I stumbled upon what I believe to be a bug in WPILib. The PIDGet for the AnalogChannel says it returns the average voltage of the channel in its documentation. However, it returns the average value, which is quite different.
 * Get the Average voltage for the PID Source base object.
 * @return The average voltage.
double AnalogChannel::PIDGet()
	if (StatusIsFatal()) return 0.0;
	return GetAverageValue();
I confirmed this in code by noting the disparity between GetAverageVoltage and PIDGet when output to the console.
Has anyone else seen this problem? Is the average value the standard behavior? My workaround was to subclass AnalogChannel for the time being.
I have installed all the lates updates, I am using the latest version of the reference and WPILib source, and have re-imaged the the cRIO with this year's image.
Unread 15-01-2013, 08:16
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
I would file a bug with the tracker on firstforge.
Unread 16-01-2013, 01:42
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Bug in WPILib
I agree that this is a bug and I agree that you should create a tracker.
Unread 16-01-2013, 18:43
zsnow's Avatar
Head of Satire
AKA: Zachary Snow
Re: Bug in WPILib
I have submitted this to the WPILib tracker.
http://firstforge.wpi.edu/sf/tracker..._bugs/artf1583
