Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
Unread 13-01-2013, 00:42
kearnel kearnel is offline
FRC #2771 (Code Red Robotics)
kearnel is an unknown quantity at this point
"Waiting for cRIO to reboot" forever
So, last time tried to load code onto the robot the Netbeans output got stuck at the "Waiting for cRIO to reboot" part. here is some output:
Sending local file image.suite
run:
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
   Waiting for cRIO to reboot (8s)
   Waiting for cRIO to reboot (9s)
   Waiting for cRIO to reboot (10s)
   Waiting for cRIO to reboot (11s)
   Waiting for cRIO to reboot (12s)
   Waiting for cRIO to reboot (13s)
   Waiting for cRIO to reboot (14s)
   Waiting for cRIO to reboot (15s)
   Waiting for cRIO to reboot (16s)
   Waiting for cRIO to reboot (17s)
   Waiting for cRIO to reboot (18s)
   Waiting for cRIO to reboot (19s)
   Waiting for cRIO to reboot (20s)
   Waiting for cRIO to reboot (21s)
It never stops "Waiting for cRIO to reboot". This obvisuly makes it impossible to see the output from the cRIO. I'd really like to see the output in netbeans for debugging purposes.
things I tried:
Rebooting the cRIO
Reimaging the cRIO
Restarting netbeans
btw, someone else's laptop downloaded code to the same robot without the issue.
I looked around the CD forums here and it seems that I am the only one with this issue. Help would be much appreciated. Thanks
Unread 13-01-2013, 00:56
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: "Waiting for cRIO to reboot" forever
You could always use the NetConsole, at least until you find a solution. We had an issue like this once, and it had to do with the subnet mask. We ended up just re-imaging the code computer though...
Edit: Though, if you use the NetConsole, you might have to end the deploy program first.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 13-01-2013, 03:18
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
A quick use of the search (with the error "waiting for cRIO to reboot" in the search box) reveals this thread from last year:
http://www.chiefdelphi.com/forums/showthread.php?t=100022&highlight=Waiting+for+cRIO +to+reboot
we had the same issue at some point, it really is annoying! But it forced us to use the output on the Driver Station, so now we use both. Every problem is an opportunity to learn a new skill
www.sharkattack744.com
Unread 16-01-2013, 00:44
I tried all the advice in that thread. I also reinstalled the JDK, Netbeans and the FRC plugins. I still have the same issue. The only thing that I noticed that was a little funny is that some how through the reinstalling netbeans rembered my team number (no other settings though).
Unread 16-01-2013, 19:41
What firewall and antivirus are you using? Have you tried disabling them?
Unread 16-01-2013, 19:52
Lalaland1125 Lalaland1125 is offline
AKA: Ethan Steinberg
FRC #2429
Lalaland1125 is an unknown quantity at this point
My team usually had this issue when we were on the wrong IP. Make sure your IP is set statically to 10.xx.yy.5.
Unread 16-01-2013, 21:09
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Try turning the robot on then off while uploading it is trying to tell you to reboot the robot i believe.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 16-01-2013, 23:02
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The last number can be any number that's not 1, 2 or 11. Typically, the driver station will be 5, so you can't have the programming laptop have the same IP address.
