Go to Post The worst that happens is we try our best and lose. And there's no shame in that. - pfreivald [more]
Unread 16-01-2013, 22:00
Rosstafari Rosstafari is offline
None #2443
Rosstafari is an unknown quantity at this point
D-Link issues
So our team is setting up our d-link.We have encounter a issue with the D-link connecting to our cRio. We have followed the instructions given to us in the "Getting started" and use the bridge configuration to set it up. Our cRio is not the problem.
Unread 16-01-2013, 22:16
Re: D-Link issues
You didn't say what the "issue" is.
Unread 16-01-2013, 22:19
None #2443
Re: D-Link issues
Our problem is getting our D-Link to connect to our cRio.
Unread 16-01-2013, 22:30
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: D-Link issues
You've got to be more specific.
What have you tried? Is the router otherwise functional (can you connect to it normally - as in a regular wifi connection)? Is it giving you an error code? Are the lights flashing orange? When you try to deploy code, what is the failure message? Can you verify that everything works with last year's router?
etc. etc.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 16-01-2013, 22:38
None #2443
Re: D-Link issues
The lights are all the normal on the D-Link. When we try to deploy code it fails when it tries to connect to the cRio. We try pinging the cRio and get no response. If need more information just tell me what you need.
Unread 16-01-2013, 23:17
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: D-Link issues
When you deploy code is the driver station program running? Try it again with the driverstation exited. No need to fully shut down the computer.
Unread 17-01-2013, 08:51
Re: D-Link issues
Investigate systematically.
Start by connecting your laptop directly to the cRIO via Ethernet cable.
That'll make sure there isn't a problem on the laptop or cRIO end.
Second try connecting both your laptop and the cRIO to the DLink with an Ethernet cable. The DLink doesn't take any setup to make that work.
Once that works, then try a wireless connection between the laptop and the DLink. That will isolate the problem to the wireless settings.
