Go to Post We may not have any Paris Hiltons around here (though I've heard Paul Copioli is a great kisser) - AndyB [more]
Unread 16-01-2013, 22:06
moeyo1000 moeyo1000 is offline
FRC #2522
moeyo1000 is an unknown quantity at this point
Lightbulb FRC Rules, and ideas; Flashlights...
So my team has been struggling to create a floor pickup system to grab frisbees from the ground.We have many ideas floating around, but we are having trouble on acuracy from the pits. So we had the thought that we could put a flashlight on our pickup mechanism, which is on the outside of the robots frame, so that the drivers can see the frisbees easily, and then pick them up.
So the question i pose top you lovely folks is, can you have a flashlight, laser pointer, etc on your robot?
And..... if so can said device have an internal batery, or does it have to be connected to the robots main power source?
I would like some feedback, from all you lovely folk, please reply so that our designing process can quickly proceed.
Thank you alot from FRC team 2522 Royal Robotics.
Unread 16-01-2013, 22:16
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: FRC Rules, and ideas; Flashlights...
Yes, you can use a flashlight. No, you cannot use a laser pointer. If you mount a flashlight, it has to be powered by the robot's battery.
Look up videos of team 180 in action from last year if you want to see how flashlights can be used for targeting goals and game pieces. With any luck, Bryce will show up and give us some pictures as well.
Unread 16-01-2013, 22:18
GaryVoshol's Avatar
Cogito ergo arbitro
A light on a robot extension wouldn't be inherently illegal. You'd have to power the light off the robot battery, the only power source allowed. And follow all proper circuit rules. Also, the arm would have to be retracted inside the FRAME PERIMETER for the STARTING CONFIGURATION.
(since 2004)
Unread 16-01-2013, 22:20
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
I don't have the rules in front of me so take this with a grain of salt. THere is a rule specifically about allowable power sources. You would have to power the light off of the robot's main battery through the power distribution board. As for lasers I think there is a rule about the class of laser and where it can be pointed. There are a couple of ideas for floor loading floating around on Youtube...Right after kickoff I know a number of people were talking about using impellers powered using a fisher price motor to suck the disks off the ground enough to catch them up on rollers.
I would suggest you look for a solution that has much greater tolerance. The last thing you need during a 2 minute teleop period is to have your team hunting around trying to line up perfectly on a frisbee using a wifi camera that has limited bandwidth.
This is just my opinion though...
R-34 for the battery...Can't find the one about lasers...
Edoga
Unread 16-01-2013, 22:21
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
From the rules (sorry that I'm bad at formatting):
"4.1.2.1 R08
ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the
operation of other ROBOTS.
Examples of items that will violate R08 include (but are not limited to):
D. Exposed lasers other than Class I."
Yes, you can use class I lasers. 188 used a 3 laser array to aim last year, and many teams used flashlights.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 16-01-2013, 22:35
Botwoon's Avatar
"4.1.2.1 R08
Pardon me, I was under the impression that class I lasers weren't even visible. Is there a process for proving that the laser you have mounted on your robot is a class I laser?
Unread 16-01-2013, 22:49
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
188's lasers were clearly visible on the backboards from behind the driver station wall (across the field).
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 16-01-2013, 22:51
AKA: Brian Smist
I may have jumped the gun a little bit in making that connection. I assumed that the rules from last year about lasers are the same as this year's, and that's not a safe assumption. I know for a fact that 188 had lasers on their robot last year that were visible on the backboard for aiming. I'm not sure about the inspection process, if someone from 188 sees this and wants to chime in that would be good.
Also, I just checked last year's manual and the rule is the same. So it's safe to assume 188's lasers were class I.
For what it's worth, it would probably be a lot easier to implement a flashlight, but both are legitimate options.
Unread 17-01-2013, 00:06
Gregor's Avatar
Quick Wikipedia search finds
A Class 1 laser is safe under all conditions of normal use. This means the maximum permissible exposure (MPE) cannot be exceeded when viewing a laser with the naked eye or with the aid of typical magnifying optics (e.g. telescope or microscope).
Would someone on 188 mind (laser ) pointing us in the right direction as to what lasers you used.
<Since 2011
Unread 17-01-2013, 07:58
One other thing to keep in mind is that your light source cannot be a hazard or impair the vision of other participants. No mini-suns please!
Unread 17-01-2013, 08:40
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
I imagine one of those LED ring lights (typically for the Axis camera) should provide sufficient light (at least my eyes hurt when I stare at them )
It looks like they are out of stock on AM, but you may be able to make a "custom circuit" using the innards of an LED flashlight and connect it to your robot power.
Unread 17-01-2013, 09:09
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
You should have seen team 25. A Flashlight? How about a car headlight.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 17-01-2013, 09:10
protoserge's Avatar
We use Fisher-Price motors... maybe a Power Wheels headlight???
Unread 18-01-2013, 12:00
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Visibility depends on the light frequency, not the power level.
Lasers are legally required to be clearly marked by the manufacturer with their class (based on radiated power). This wikipedia article has pictures of the current standard labels. This is a good example of the older-style labels. Laser pointers are almost never class I.
Unread 18-01-2013, 12:07
If an inspector cannot tell from markings on the device that it is a Class I laser, you will have to show documentation to prove it prior to powering the device.
