Go to Post And people laugh at me when I suggest 14" wheels. - Munchskull [more]
Unread 12-01-2013, 14:33
1757 1757 is offline
FRC #1757
1757 is an unknown quantity at this point
Alternatives to kinect
Can this work as an alternative to the kinect's infrared system?
http://www.google.com/shopping/produ...d=0CLIBEPMCMAU
Unread 12-01-2013, 15:52
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Alternatives to kinect
I think you misunderstand how the Kinect works. The Kinect only uses IR to generate a depth map of the objects in front of it. It does so by projecting tiny dots from an IR laser onto the surface. It does not flood the FoV with IR light as the camera you linked does.
You can still use the camera, but you may have to write your own class to handle it, and it may not work very well compared to the Axis camera depending on what your purpose is (latency, etc.)
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 12-01-2013, 16:44
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
the axis camera has the ability to to do what I think you are looking for. Plus there are many different examples from previous seasons that you can use.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 16-01-2013, 15:18
FRC #1757
No, think 'night vision'. I need a IR sensitive camera that can show a picture using IR rather than visible light. The kinect can do that.
Unread 16-01-2013, 16:00
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
The camera you linked is just a camera with no IR filter, and an IR light.
The Kinect is 2 cameras, one only sees a specific range of IR, and the other only sees visible light. It has an IR laser that projects a grid of light, and using the IR cam to find the size of the dots, generates a gray-scale colored by depth view.
For vision tracking proposes the one you linked might work well, assuming the vision targets reflect IR. It will still pick up visible light however, not just IR.
TLDR: Kinect is a depth cam, and the other is night vision.
Unread 16-01-2013, 22:41
F22Rapture's Avatar
AKA: Daniel A
Just curious... why exactly do you need night vision?
- Wernher von Braun
Unread 16-01-2013, 22:50
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
If you use IR instead of visible light you can ignore most ambient light and only see what is being bathed by the IR light source which is generally mounted co axially to the camera. The downside is it is not an Axis so the libraries don't exist if you want to do any automation with it.
IR IP webcams are fairly cheap on Amazon, think we picked one up for $50 or so, and it runs on 12 Volts. Doubt it will make it on the robot due to automation but it was neat to play with and see how different the feed looks when you are ignoring ambient light and just looking for the retro-reflective tape.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 17-01-2013, 11:59
FRC #1757
That HTTP_GET module for roborealm works fine for all IP Cams I've tested.
Unread 17-01-2013, 23:14
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
A little off-topic, considering that you look like you are more interested in infrared illumination than depth mapping, but a plausible alternative (that is both lighter and less power-hungry) to the Kinect is the Asus Xtion (http://www.asus.com/Multimedia/Xtion_PRO/) - I think it even runs on much the same drivers as the Kinect.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 18-01-2013, 01:55
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
"Most" is the right way to put it. Last year, we were surprised by the brightness of the nets, when viewed with an IR camera.
One does need to be aware of the amount of IR illumination being provided. Depending on power, frequency, and duration, there is the potential for damage to the human eye.
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
