Re: Drive Belt vs. Chains
If you don't have any experience with belts then use chain. However if you have experience with belts or know someone who has experience using belts, use belting. I only say use belting because its significantly lighter then chain, and to some aspects easier to use. Such as you don't have to deal with breaking the chain and re-attaching together.
My team has had many bad experiences with belts, so we tend to stick with chain. In 2011, we had belts drive our tube manipulator, and the belts would slip and it would render it ineffective. Chains rarely slip, normally they just snap or break, but its much harder to get a chain to malfunction than it is to get a belt to malfunction.
http://www.youtube.com/watch?v=MgYnw...XrOpK1&index=2
This is a great resource to see an effective way of running power transmission in a WCD, or any other base style, for that matter. |
That is also true, and I should have mentioned it. A simple, robust drivetrain goes a long way in FRC, and more complex designs need time to be developed.
#7
Keep in mind the old adage: KISS (Keep It Simple, Stupid). FRC isn't the place to optimize every little bit out of a design. You do not want a perfect robot, you want a good enough robot.
