Go to Post Coming to MTV this fall: Pimp my Segway - Francis-134 [more]
Unread 16-01-2013, 23:27
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Camera Problems
Originally Posted by lorem3k View Post
Yes, you need to either plug in the wall plug or the 5V power on the PD board (depending on whether or not you've made the cable already).
There should be a cable that came with the camera that lets you plug it into a wall outlet. You can set up the camera using a wall outlet. To use it on your robot, snip the cable close to ac/dc adapter (black box that plugs into the wall) and wire it to the +5v output of the power distribution board.
Once you get lights to blink, you can read through this to get it configured
