Go to Post No, Dave says "that's PUMP" - dlavery [more]
Unread 16-01-2013, 15:57
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Three Level Climber Design
This design is one that our team decided not to use, but I thought it was good enough that I did not want to just let it die. By posting the design here I am hopeful that it might help some team. You are welcome to use it however you wish.
If anyone out there would like to start modeling in inventor an open source model, I will host it on a SVN server making it available to anyone that wants access.
If you want to actually build this and need help I will do my best to help you through the finer details.
If you have any questions, post them in this thread.
http://hughmeyer.com/DesignIdeas/FRC...berDesign.html
Good luck to all teams!
-Hugh
Unread 16-01-2013, 23:08
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Three Level Climber Design
Thank you for sharing. It is a somewhat complex (or maybe intricate) design, but at a minimum, it should give teams some good ideas.
Better than anything we've come up with.
Unread 16-01-2013, 23:49
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
I believe a side view of the robot (just a drawing) in its different stages would help greatly in understanding how this works.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 16-01-2013, 23:58
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
If I understand correctly what this is, we looked at something similar during the first couple days.
I must say it is a great design and we have the manufacturing capabilities to do it, we just found something that was more in the Pigmice style (involving massive pistons).
Good luck and thanks for sharing.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 18-01-2013, 17:14
CobolWhisperer's Avatar
CobolWhisperer CobolWhisperer is offline
Your message here, $20/month...
AKA: Ed Anderson
FRC #2220 (Blue Twilight)
CobolWhisperer is an unknown quantity at this point
Similar to a design I thought of. I just wonder what your thought was for keeping the bot from rotating backward when you put downward pressure on that first rung, 'cause I couldn't convince myself I could prevent it.
Unread 19-01-2013, 04:19
Hugh Meyer's Avatar
The weight distribution of the robot would need to have the center of gravity such that it tilts forward to engage the top fingers to the 2nd level bar. Mounting the battery in the front of the robot should help this. If you look at the robot in 3 days videos they talk about this in their design. As you see on the list of negative features, you have correctly identified one of the "tricky" parts of this design. If you notice mounting flanges are oriented such that the system can be mounted at any location on the frame. This will allow the option to experimentally determine the best position using clamps before committing to drilling the mounting holes.
-Hugh
