Go to Post Just wait till Heidi learns video-editing skills. - tkwetzel [more]
Unread 16-01-2013, 23:25
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
CIM->Victor 884->Arduino not working
I'm trying to control a CIM Motor (Foward, Reverse, Stop, Etc.) with a Victor 884 controlled by an Arduino Uno Microcontroller. So far I've tried a couple different things and well I'm fed up and figured I'd show you guys how everything is hooked up to see if someone see's what I'm doing wrong.
Before you guys respond I want to set a few things: I'm not going to use a Crio I'm not going to use the IFI control system I'm not using a FIRST control system. It doesn't matter if any of this is against FIRST rules I'm not doing this for FIRST. However despite the fact that this is not for FIRST I'm going to ask the questions here because it contains the largest amount of people that could help.
This is how everything was hooked up originally and I've also tried hooking up a mosfet powered by the 5v line of the arduino. And I've also tried putting a 5v regulator powered by the FRC battery and then using the 5v line to power a mosfet to boost the signal to the victor, but everytime the victor just flashes orange (no pwm)
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 16-01-2013, 23:32
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: CIM->Victor 884->Arduino not working
Have you tried connecting the grounds between the FRC battery and the Arduino?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 16-01-2013, 23:40
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I've never tried this personally, but if I had to hazard a guess it would be that delay takes an unsigned long as an argument, but you're passing a floating-point time. You probably want to use delayMicroseconds(). Also, the WPILib comments say that the Victor prefers 10ms periods.
You might also want to check out the Servo library. It's designed for servos that go to specific angles, but it should work for this case as well. I think you'd want to use writeMicroseconds() for the high pulse, and then just delay for the remainder of the period.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 16-01-2013, 23:51
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
You want to use the Arduino Servo class to generate a PWM signal.
Connect the cable to a PWM pin rather than a DIO and use the functions in the Servo class to drive the Victor.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 17-01-2013, 00:01
The ground pin on a Victor is at the other end of the PWM input connector from the signal pin. The center pin is not used, but it's typically labeled as the power input. Your picture shows the ground and power connections reversed.
Unread 17-01-2013, 00:17
jamie_1930's Avatar
Team Role: Student
The pin on the arduino and frc battery are grounded together i forgot to put that in. Also the pwm wires on the victor are correct in real life I forgot to put them in the right order in the drawing. Also the servo library gives the same results
2009
2008
Unread 17-01-2013, 03:45
TAHIRisHERE's Avatar
TAHIRisHERE TAHIRisHERE is offline
FRC #0334
TAHIRisHERE is an unknown quantity at this point
you will have to use the aruidno servo library to have the arduino generate PWM signals. As seen here, http://playground.arduino.cc/ComponentLib/servo
you would have to attach the black wire(from victor) to any ground pin.
Then the white to an arduino pin with PWM(i think its has a curvy line next to pin number label.)
Then the red wire you have no use for.
so a simple sample:
#include <SoftwareServo.h>
Servo myservo(any name can be put here this example uses myservo); // create servo object to control a servo
// a maximum of eight servo objects can be created
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
{ myservo.write(0) (writing the servo at value of 0 will spin motor full speed coutnerclockwise. and a value of 180 will spin motor to full speed in clockwise direction. and a value of 90 is no spin or stop) }
I will assume you know how to wire the battery to the victor.
the sample code is not perfect there are mistakes. but i hope it helps.
Unread 17-01-2013, 04:38
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I've done a similar project before, but with Jags instead. I used the PWM generating function onthe Arduino, and I beleive I mapped the desired power value onto a 900 microsecond to 2100 microsecond range (full reverse to full forward).
With the Arduino, I've always found that the premade libraries work far beter than a function you tried to put together yourself. Just a word of advice.
-Plutarch
Unread 17-01-2013, 08:40
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
You can use the analogWrite() function for PWM so you don't need the Servo library. (that is not a typo, analog, not digital even though you are on a digital pin)
We are currently using this on our test disc shooter.
I did find that the PWM output is not a perfect match for our Victor (an old one, not an 888). Even after calibrating I found that a value above 253 caused a problem.
We are using a potentiometer as input and map the ADC range of 0-1024 to 183 to 253 (one direction, deadband) works pretty well for our particular Victor. You should probably profile yours to find a good range.
I have not put a scope on the PWM out, but I supect it (the output pulse width) is not perfect for the Victor.
HTH
Unread 17-01-2013, 13:19
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
This is working code, I have two pots, one is set only goes one direction, the other pot goes full rev -> 0 -> full forward. This was hacked together a couple of years ago, and put in an Altoids can, we are using it to prototype again this year.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
Servo myservo1;  // create servo object to control a servo
int potpin = 0;  // pot in is 13 pwm analog pin used to connect the potentiometer
int potpin1 = 1;  // analog pin used to connect the potentiometerint val;    // variable to read the value from the analog pin
int val =0;
int val1=0;
void setup()
 myservo1.attach(10);  // attaches the servo on pin 9 to the servo object
void loop()
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023) //
  val1 = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  val1 = map(val1, 0, 1023, 90, 179);     // scale it to use it with the servo (value between 0 and 180)
   myservo.write(val);                  // pwm 13 sets the servo position according to the scaled value
   myservo1.write(val1);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
The sooner we get behind schedule, the more time we have to catch up.
Unread 17-01-2013, 13:30
jamie_1930's Avatar
Team Role: Student
#include <Servo.h>
int val =0;
int val1=0;
void setup()
void loop()
Could you show me how you set up this up electrically? In the victor manual it says to use a pwm signal driver if you are not using an ifi controller and I can't really find one on the internet. So I assumed I could boost up the amount of current by using a mosfet. I got that working and then I measured the current over time with an oscilliscope and it's pretty noisy. The voltage is a perfect square wave, but the current starts of at 0A and curves up to around 500mA and does a 10-20mA bounce as it goes up.
2009
2008
Unread 17-01-2013, 13:32
Originally Posted by jamie_1930 View Post
..500mA
You are pushing 500 ma into the Victor's opto-isolator ??
Unread 17-01-2013, 14:37
jamie_1930's Avatar
Team Role: Student
That's what I got on the o scope. I put a 10 ohm resistor in line with the signal wire and took the voltage above and below the resistor then hooked the other channel on the o scope to a constant 0.1v and used the math function to multiply the channels
V=IR
I=V/R
I=Voltage drop across resistor/10 ohms
I=Vresistor*.1
2009
2008
Unread 17-01-2013, 15:29
500 ma seems way too high. You might even have damaged the opto-isolator's emitter.
I've never been able to find a Victor schematic, but the datasheet for the Jag's opto-isolator says it has an absolute maximum continuous current rating of 60 ma for the input.
The cable I am using for my test equipment here delivers about 5.6 ma to the Victor during the pulse, and it works fine.
Can you post a picture of your scope's current waveform?
Unread 17-01-2013, 15:44
jamie_1930's Avatar
Team Role: Student
I won't be able to get back into the school till later tonight or tomorrow, but I'll get that to you as soon as i can. Next time i'll try putting a larger resistor in line to lower the current down to 50mA and see if that changes anything. I just hope i haven't damaged the victor.
2009
2008
